2006 Cadillac DTS Signal light bulb
FDSHRINER
  • 2006 CADILLAC DEVILLE DTS
  • 4.0L
  • V8
  • FWD
  • 93,000 MILES
I have a 2006 Cadillac DTS with approximately 93000 miles. The left sides blinker, yellow one has gone out and I need to replace the bulb. I have had no problems with these things on other vehicles in the past however, I have no idea where to start on this vehicle. Any help is appreciated.
Wednesday, November 27th, 2013 AT 5:03 PM
  • 108,179 POSTS
Open the hood and see if you can access it through there. Let me know.
See diagram below
Wednesday, November 27th, 2013 AT 5:04 PM
LARRY MAHLER
  • V8
  • FWD
  • 77,380 MILES
How do you replace the right front turning signal bulb?
Sunday, January 27th, 2019 AT 8:36 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
You must remove the headlamp lens to replace the turn signal bulb. Here is a guide to show you what you are in for when doing the job with diagrams (below) of what it will be like for your car.
https://www.2carpros.com/articles/turn-signal-bulb-replacement
Check out the diagrams (Below)
Cheers, Ken
LARRY MAHLER
That was great thanks for the information I just saved $150.00 bucks! I love this site
SMORK 88
  • 2008 CADILLAC DEVILLE DTS
  • V8
  • FWD
  • 58,000 MILES
The left front turning light bulb turned black (blowen out) and is non-functional. Bought a replacement, raised the hood to gain access and was immediately baffled. How in this world are we to gain access to replace this bulb?
FACTORYJACK
  • 4,159 POSTS
It is necessary to remove the front fascia. It is an intelligent design. I have had the luxury of doing about 5 vehicles in the past week, CTS, SRX, and STS are about the same. I think it is becoming standard of the industry and not just GM. Depeding on your relationship with your selling dealer, they may provide goodwill assistance and replace it under warranty. It would be worth asking.
J.FISHER
  • 2007 CADILLAC DEVILLE DTS
Electrical problem
2007 Cadillac DTS
how do you replace a bulb in the headlamp
FACTORYJACK
  • 4,159 POSTS
To get the lamp out, the front fascia has to be removed. This is not that complex, it just requires the wheelhouse liners, the lower splash shield, the upper plastic push-pin retainers, and the bolts at the fender to fascia seam(accessed in the wheel wells)
J.FISHER
Electrical problem
2007 Cadillac DTS V8 Front Wheel Drive Automatic
how do you change a front headlight bulb
FACTORYJACK
  • 4,159 POSTS
Check your other post. If this is a HID lamp, it may not be just a bulb, you have a ballast to be concerned with. If it is just halogen, disregard.
