2002 Cadillac DTS Repair Question
Asked on April 3, 2009
2002 Cadillac DTS window
Interior problem
2002 Cadillac DTS V8 Two Wheel Drive Automatic 46000 miles
The passenger window will go down when engaged but not up. You can hear the motor running. What is the most likely problem?
Answer
Replied on April 3, 2009
Most likely is the regulator, it is a cable drive type and prone to failure. You can probably pull the window upward with your hands. It may just be going down by its own weight. Do you have an extended warranty? This regulator is not cheap, the tune of around 400 bucks for regulator w/motor, and thats not including labor.
