2001 Cadillac DTS
2001 CADILLAC DEVILLE DTS
102,000 MILES • V8 • FWD • AUTOMATIC
RICKCRABB
it blows warm air out on the drivers side and cold air on pasenger side and rear. i have changed the climate control panel, but it made no difference.
Jul 10, 2010 at 5:00 PM
FACTORYJACK
  • CAR REPAIR CONTRIBUTOR
  • 4,159 POSTS
If this happens when A/C is selected, you could have two possibilities. The first could be low refrigerant charge. The fact that the drivers side blows warm, is because it is furthest from the evap core. The second is a faulty air mix actuator. Often times if the air mix actuator overtravels, or falsely triggers an overtravel, it will default to full heat.
Jul 13, 2010 at 11:20 PM
