Engine wont turn over?
BILLY TUCKER
  • 2004 CADILLAC DEVILLE
  • V8
  • FWD
  • 47,000 MILES
Engine wont turn over or boost battery voltage is right at 12v
Thursday, March 19th, 2009 AT 12:55 AM
Sounds like it won't crank over at all/nothing by itself or the boost battery, it sounds like the starter is no good but to be sure here is a guide to help confirm the issue.
Thursday, March 19th, 2009 AT 1:11 AM
2CP-ARCHIVES
  • 4,542 POSTS
  • 2001 CADILLAC DEVILLE
  • 20,800 MILES
When attempting to start the car there is a clicking noise at the starter. Car never completely turns over and turns real slow. Replaced battery with new. Put a new starter in, but same result.
Friday, June 12th, 2020 AT 11:28 AM (Merged)
Go and review this link for more information:
STN1
  • 2003 CADILLAC DEVILLE
Electrical problem
2003 Cadillac Deville V8 Automatic 127000 miles
Replaced battery, power every where except to the starter. All lights on dash go out when key is turned. Does not even click. Could this be a solenoid problem, or something else.
Thanks Norm
Friday, June 12th, 2020 AT 11:30 AM (Merged)
JOE LORENTI
  • 6 POSTS
Easy test to do.
Turn on your headlights.
With someone looking at your headlights, try to start the car. If your headlights do not dim, then it means that your starter is either no good, or you have a broken connection in the fuseable link. A fuseable link wire acts like a fuse. When overheated, whether it be internal or external, the connection may break internally. The wire may look good from the outside and that's where most people are fooled and many mechanics make a home run in billing the customer, they charge the customer for a new starter when really all they replaced was a 2$ fuseable link.
I hope this solved your problem, Let me know.
MONA_AFLAGUE
  • V8
  • FWD
  • 138,000 MILES
I took my car into a dealership last week and they said the code read that there was a fuel deficiency. Today when I went out to the car it wouldn't even crank. Not sure what the problem is.
Friday, June 12th, 2020 AT 11:37 AM (Merged)
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
check out this link to test if you are getting fuel
LEGITIMATE007
  • 5,121 POSTS
Go here to see if you are getting any spark
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
LEGITIMATE007
  • 5,121 POSTS
Does the car atleast sound like it wants to start? There is a difference between crank and turn over.
MONA_AFLAGUE
No, it doesn't do anything. I hear the fuel pump turn on but that's it. The lights come on, the radio run and everything else just not the car. There is absolutely no sounds when turning on the ignition.
RADIOACE
  • CADILLAC DEVILLE
Yesterday evening 2/1 my car started without any
problems.I went out early this morning 2/2 and it would not even turn over. I check the batter voltage it was 12.72 Volts. Is there something else that I can check before paying a ridiculous towing fee and repair bill. Is there a fuse or cellinoid that I can check on the electrical system that would keep the car from starting. It is a 1997 Cadillac Deville?
Thanks
GARFIELD
  • 197 POSTS
You can check to see that you are getting 12 volts at the starter cables connection(the wire coming from the postiive post of the batttery. Next disconnect the small wire lead at the starter solenoid(known as the S terminal) with it disconnected attach a voltage meter to the disconnected wire and attempt to start the car and see if you are getting 12 volts when the ignition switch is in the start position. If you are not getting voltage at that wire then you either have a wiring issue between the ignition switch and the starter or the ignition switch itself is bad and needs replacing.
LEGITIMATE007
  • 5,121 POSTS
Check this out too
show you how to check your battery and alternator
https://www.2carpros.com/how_to/battery.htm
CLEAVAGE4U
  • 69 POSTS
Daddy says you should check all the connections from and to the battery for cleaness and tightness.
2CARPRO JACK
  • 11,533 POSTS
97, what engine? Makes a huge difference in being able to access the cables and trigger for testing at the starter
