2000 Cadillac Deville Repair Question
2000 DeVille Crankshaft Position sensor circuit
Answer
There was actually a tech service bulletin on those years where one crank position sensor would cause the other to fail. Its not a a hard fix, but I suggest you invest in a "Haynes" or similar repair manual which will give illustarted pics and tips on what else needs to be removed in order to replace them.
I have a 2003 Deville. Both sensors (upper and lower) are above and to the front of the oil filter. They are located behind the front engine support. I replaced mine today and thank God I have small hands. It took about 2 hours to remove them. You also have to remove the plastic pan under the front of the car. Installing new sensors ($40 each) went much quicker and no more stalling after driving the car about 1/2 hour. Last night I took the family to a restaurant across town and it stalled twice on the way there. I read on another post that Cadillac dealers charge $300 to replace them. Also, you do not have to drain the oil. The connectors were a pain, until I figured out how to remove them. Be very careful not to break them.
you still have to go to the dealer to do a crank shaft position relearn, codes will still appear,
How exactly did you manage to get the crank sensors off. I found a diagram of where thye are but I cant quite see them from under the car. Did you remove the front motor mount or just squeeze your hand in there. And once I do find them, How do I unclip them? Thanks for any help, Ian
