oxygen sensor replacement?
2003 CADILLAC DEVILLE
102,000 MILES
VROOM
where is oxygen sensor 1 bank 2 located I need to replace it
Apr 22, 2012 at 6:25 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,334 POSTS
Here is a guide and the locations of each of the oxygen sensors so you can get the job done.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Check out the diagrams (Below)
Cheers, Ken
Feb 13, 2018 at 1:18 PM
FACTORYJACK
  • 4,159 POSTS
The bank 1 sensor is accessed from the top of the engine reaching over the rear, it requires a long extension and a 7/8" crowfoot or sensor socket. The bank 2 in front, is accessed from below after the lower shield is removed. The front of the frame may be lowered a bit for more access.
Feb 13, 2018 at 1:19 PM (Merged)
SIKWITIT765
  • 6 POSTS
Computer problem
2001 Cadillac Deville V8 Front Wheel Drive Automatic 85890 miles
how do u remove the oxygen sensor before catylytic convertor on a 2001 cadillac deville .it wont budge off for nothing
FACTORYJACK
  • 4,159 POSTS
Spray it with some penetrant, and try it when it is warm. If it has been overtightened, the threads may have stretched. You may need a thread chaser(14mm spark plug tap) to clean the threads after removal.
ALIMO
2001 Cadillac Deville V8 Front Wheel Drive Automatic 82000 miles
I pulled code p135 on my scanner and the result is sensor 1 bank 1, this is the Co2 sensor at the back of the engine. ( Northstar V8 )
Can I not get the sensor out ! the thing is laughing at my attempts, has anyone found a trick to removing the faulty part ( and yes I did have the engine hot and burned my hands too ! )
Many thanks
Alan
FACTORYJACK
  • 4,159 POSTS
If you have tried it hot, and cold, and it still won't loosen, there is not much choice but to remove the manifold. What tools are you using? It is a 7/8" hex, and a crowfoot, or sensor socket is advised. If you are not slipping around it, and you are committed to get it out, then give it all you got. I have even adapted up to 1/2" drive to break them loose. If it pulls some threads, you can use a standard spark plug thread chaser to clean the hole up.
ALIMO
[quote:75191e04cd="gstacey"]If you have tried it hot, and cold, and it still won't loosen, there is not much choice but to remove the manifold. What tools are you using? It is a 7/8" hex, and a crowfoot, or sensor socket is advised. If you are not slipping around it, and you are committed to get it out, then give it all you got. I have even adapted up to 1/2" drive to break them loose. If it pulls some threads, you can use a standard spark plug thread chaser to clean the hole up.[/quote:75191e04cd]
Yep, I'm using a sensor socket, guess I'll have to get angry and turn green to get it out !
MADD5
Where is it and how do you change it?
Jan 30, 2019 at 7:11 PM (Merged)
BLACKOP555
  • 10,386 POSTS
bank 1 is located on the side of the car engine that the #1 cylinder is on car right after the exhaust manifold before the catalytic converter. simply unhook the wires and then simply unbolt the sensor.
See the diagram below for which cylinder is #1
OSEA
Other Category problem
1996 Cadillac Deville V8 Front Wheel Drive 131555 miles
i have a p0133 code bank 1 sensor 1 slow response where exactly is the snsr located already purchased snsr just need 2 know where its located thanks for all help
BMRFIXIT
  • 19,053 POSTS
The P0133 code indicates a slow response from the oxygen sensor (Bank 1 Sensor 1) in your 1996 Cadillac DeVille. This sensor is located in the exhaust system of your vehicle.
In the case of the 1996 Cadillac DeVille, Bank 1 refers to the side of the engine where Cylinder 1 is located. Sensor 1 refers to the oxygen sensor located before the catalytic converter in the exhaust stream.
To locate the Bank 1 Sensor 1 oxygen sensor in your Cadillac DeVille, you'll need to look underneath the vehicle, specifically on the exhaust manifold or exhaust pipe near the engine. The sensor is usually mounted in the exhaust system, with a wiring harness connected to it.
It's important to note that the specific location may vary slightly depending on the exact model and engine configuration of your DeVille. Consulting the vehicle's service manual or referring to online resources with detailed diagrams can provide you with more precise instructions for locating and replacing the oxygen sensor.
2CP-ARCHIVES
  • 4,540 POSTS
where is the location of the po135 heated oxygen sensor ho2s heater circuit bank1 sensor1(rear bank) and what does it control car just smoking and missing after po300 pop up can you help me thank you
no connection to the issue. it is a control code for the heater in the o2 sensor only. most likely a bad sensor and would have to be replaced.
it is on the rear exhaust manifold
2CP-ARCHIVES
  • 4,540 POSTS
code po147 heated oxygen sensor(ho2s) heater circuit bank1 sensor 3 (post converter) I would like to know where it is located thank you marry joe
WRENCHTECH
  • 20,761 POSTS
https://www.2carpros.com/images/external/56533093.gif
J.WASHINGTON
Replacing oxygen senser,after market sensor has to be spliced to old sensor plug. Wires on old plug has 2 brown,1 tan 1 purple wire. New sensor has 2 white,1 black,1 grey wire.My question is what wires should be spliced together?
  • 31,937 POSTS
Hi there,
with out knowing what brand of O2 sensor you have, theres no way of knowing what is what, even with that info i may be hard to track down the wire code.. is there anything on the package re instructions...
Mark (mhpautos)
BUZZSAW
  • 1,198 POSTS
[quote:bf1e7c1e98="mhpautos"]Hi there,
Mark (mhpautos)[/quote:bf1e7c1e98]
take it back and go get a GM one, your only going to cause problems in the long run
MAL FENDER
The car is driven very little, as the mileage will indicate. A local parts house read the "service engine soon" light problem and the #2 O2 sensor was what was indicated.
FIXITMR
  • 9,990 POSTS
do you have code #? #2 sensor is not enough info.
MAL FENDER
No, I do not have the code.. The parts guy showed me the sensor, and said that it is in the rear exhaust manifold. How to get to it is the main question. It must be near it's plug in - since the leads are only about 12" long.
FIXITMR
  • 9,990 POSTS
so have you snooped around back there to try n locate it?
MAL FENDER
Nope... other than from the top (nothing really visable past the valce cover).. and laying on my side - I can see the Cat converter.. but the exhaust coming to it has nothing.. almost has to be in the manifold above that.
FIXITMR
  • 9,990 POSTS
yah it's a bugger. try getting behind from fender area. use hand to try and feel it on manifold.
