not getting power to the fuel pump
1999 CADILLAC DEVILLE
138,000 MILES • V8 • FWD • AUTOMATIC
ERICHAMPTON
hey i was working on a 1999 caddy deville and replace fuel pump and not getting any fire to the fuel pump. I checked all the relays and the fuse under the hood is there another relay that is some where esle on the car, aiso check the fuses in the trunk , i test the relays with a test light and where the fuel relay goes their is no fire there. dont see any crack wire or any thing do the oil sending unit has any thing to do with that
Sep 21, 2010 at 8:15 PM
  • CAR REPAIR CONTRIBUTOR
Check the fuel pump relay socket pink wire if there's power nothing here and the fuel pump fuse is good the pink wire is open between the fuse and relay socket
Sep 21, 2010 at 10:29 PM
CADIEMAN
  • 3,544 POSTS
the fuel pump fuse is in the relay panel under right side of dash. 20amp fuse we enjoy your feedback
Sep 22, 2010 at 7:52 PM
SANCHEZDANNY
ran out of gas on 1999 deville, will not start. changed fuel pump and filter. not getting power to fuel pump. cannot locate fuel pump relay. can you help?
May 23, 2020 at 11:44 AM (Merged)
SANCHEZDANNY
correction that car has 115000 miles.
FACTORYJACK
  • 4,159 POSTS
The fuel pump relay is in the underhood fuse block, in front of the left front(driver) strut tower. It is either under the flap that provides access to the mini fuses, or you need to remove the plastic cover. There will be a sticker on the underside of the cover, the legend for the fuse relay center.
SANCHEZDANNY
found it guys, Thanks! I tried to swap the replays but still won't start. need to have a mechanic trouble shoot the electrical sys. a neighbor said the fuel pump has no power. might be a modulator?
GENNIFERJOHNSON
can a fuel pump relay or fuse cause fuel from flowing to engine
BLUELIGHTNIN6
  • 16,542 POSTS
yes, if fuel pump relay or fuse is bad then it will not let the fuel pump get power to be able to pump fuel to engine..
DAVELAWRENZ
Electrical problem V8 Two Wheel Drive Automatic
power works for a few seconds on one side but other side has no power.
FACTORYJACK
  • 4,159 POSTS
The few seconds is normal as the ECM controls the relay to build rail pressure in anticipation of cranking. Check the fuel pump fuse in the underhood fuse center. If it is blown, you could have a short, but it is more probable that the fuel pump has high resistance and is drawing too many amps and opened the fuse.
MARLYMAR510
I changed the fuel pump relay and fuse and I’m still not getting any fire to the plug ! What should I do
  • 54,350 POSTS
hello,
Here is a wiring diagram that show where the power is coming from which looks like a fuse. Here is a guide on how to check for power
Check out the diagrams (Below)
Please let us know what you find.
Cheers, Ken
PAGE DENNIS
Electrical problem
1997 Cadillac Deville V8 94000 miles
My 97 cadillac Deville shut down while driving and i had the fuel Pump replaced. but the problem is that i can not get fire to the fuel pump. a gas rag at the throttle body will start the car until the fumes runs out i replaced the relay and checked all fuses and cannot get fire to the tank.
Could be the computer fuel pump control circuit of the relay, also check the oil pressure sending unit.
ZACKMAN
  • 4,202 POSTS
Do this diagnostic. You will need a DVOM (Digital Volt/Ohm Meter for this.
https://images.2carpros.com/forum/automotive_pictures/55316_97devillefuelpumprelay2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_97devillefuelpumprelay_1.jpg
MIRIAM CUERDA
my 1996 Cadillac Sedan Deville is not pumping gas into engine, I have change the battery and the fuel relay and now there is no curint going to the relay. What could be stopping the curint from going into relay?
May 23, 2020 at 11:45 AM (Merged)
  • 110,190 POSTS
If there is no power to the relay, check to make sure the wiring under the relay block hasn't come loose. If it is good, you need to trace the wiring until you find where the break is located.
PANDLMCDANIEL
Engine Mechanical problem
1993 Cadillac Deville V8 Front Wheel Drive Automatic
Car just died and now will not start. Will crank over but now fire. Pulled the fuel line to make sure getting fuel but only get pressure for 2 seconds then no fuel. Would this be the pump or maybe the relay??? Thanks for the help
It suppose to prime the engine for 2 secs-check the fuel pressure with a gauge and comeback with the readings
PANDLMCDANIEL
I am getting good pressure for the 2 seconds 44# but no fuel after the frist brust of fuel.
FACTORYJACK
  • 4,159 POSTS
That is normal to build rail pressure, if there is no continuing rpm signal the pump is shut down. You have only checked one avenue. You need to check spark, and if you have spark, check that the injectors are firing.
POPROCKS6301
  • 13 POSTS
i have got a 1983 Cadillac Coupe Deville and I am having trouble with the fuel pump. when i go to start the car it really wants to turn over, but the fuel pump won't turn pump gas to the engine. But if i put gas in the carberator then it will try to run off the gas i put in the carbirator.
we have gotten it once to run off the gas i put in the carbirator. i am debating if it is the fuel pump, fuel pump relay, or a blown or missing fuse. the problem comes, because i don't know which relay is which. can someone please give me some suggestions on this subject?
do a fuel pressure check. in most cases, it is the fuel pump itself that has failed.
POPROCKS6301
  • 13 POSTS
OK THANK YOU I WILL LOOK INTO THAT
CADIEMAN
  • 3,544 POSTS
i had the same car back in my cadie yrs. do u hear the pump run when u first turn the key on?drop the r/side under dash panel.u will see a relay panel with fuses in it.there is a 20 amp. mini fuse their marked fuel pump.use a test light or volt meter to check that voltage is there and the fuse isnt blown.we can start here.kk
POPROCKS6301
  • 13 POSTS
ok thanks cadieman. i will look into that and tell you the results when i can thank you. it might be a week or so before i can do it cause im busy so please keep watching for my reply
CADIEMAN
  • 3,544 POSTS
np gl ill be here.
POPROCKS6301
  • 13 POSTS
hey cadieman. I am sorry I have not replied in a while. ive been working on my 1983 Cadillac Coupe Deville. I changed my fuel pump.
It actually runs now. but I have 1 question. how do I clean the digital fuel injectors in the throttle body?
CADIEMAN
  • 3,544 POSTS
add Lucas fuel system cleaner. He
POPROCKS6301
  • 13 POSTS
ok i will cadieman. thank you for your help. we are still working on the car. lol
