1993 Cadillac Deville
Engine problem
1993 Cadillac Deville 6 cyl Two Wheel Drive Automatic 200, 00 miles
ok my car has been sitting for awhile, the battery went dead so ichanged it and now when I crank the car it will turn over but not crank. It sounds like its out of gas so I put some in, nothing, then I poured it directly into the carburator and it will crank but only for a second, I have changed the filter and nothing helps. What to do?
January 15, 2008.
Do you mean it cranks over but doesnt start? You need to ck for spark and then fuel psi(caddy doesnt make a 6 cylinder, until the catera) its a 4.9 v8, if no spark you need to rebuild the distributor, pick up coil and a cam sensor and a new module, and rotor, cap? Fuel well it will need a pump, its in the gas tank
Jan 15, 2008.
