Starter Replacement
2004 CADILLAC CTS
HLEVY912
Electrical problem 6 cyl Two Wheel Drive Automatic 90000 miles
How do I replace the starter and where is it located also.
Thanks ;)
Aug 7, 2010 at 9:41 PM
  • CAR REPAIR CONTRIBUTOR
Hi hlevy912,Welcome to 2carpros You will need to jack the car up https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely and disconnect the battery, here is a general guide that will show you how along with the manual diagrams (below). https://www.2carpros.com/articles/how-to-replace-a-starter-motor 2004 Cadillac CTS V6-3.6L VIN 7 STARTER MOTOR REPLACEMENT 1.Turn the ignition OFF. 2.Disconnect the battery negative cable.
https://images.2carpros.com/forum/automotive_pictures/12900_s1_7.gif
3.Remove the starter solenoid electrical connector from the starter.
https://images.2carpros.com/forum/automotive_pictures/12900_s2_6.gif
4.Remove the starter terminal nut (1) and the battery positive cable (2) from the starter.
https://images.2carpros.com/forum/automotive_pictures/12900_s3_3.gif
5.Remove the starter motor bolts. 6.Remove the starter motor. Please let us know if you need anything else to get the problem fixed.
Aug 7, 2010 at 11:30 PM
KSTONEKC
Electrical problem
2003 Cadillac CTS 6 cyl Two Wheel Drive Automatic 104000 miles
2003 Cadillac CTS, 3.2 v6, 104,000 miles my starter went out and the estimated repair was $443.00
later they called and said my flywheel needed to be replaced.
My question is: can the starter mess up the flywheel. And how can I tell if they are telling the truth.
It is at a Firestone dealer, what should I expect to be charged?
Jun 5, 2017 at 5:39 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Mitchells labor guide calls for 10.5 hours of labor to replace the flywheel, plus about $100 for the flywheel plus whatever the cost of the starter is.I would go down there and ask to see where the flywheel is messed up, it can happen from a bad starter, but you would have heard grinding noises when starting if it was hurting the flywheel.
