Mechanics
BURNT SMELL
2008 Ford F-150 • 83,000 miles
With everything turned off. My headlights and tail lights won't turn off. And I have a burning smell in my cab. I pulled a small black plug. That's in my fuse box. Thinking its a fuse or a relay. My maintenance manual doesn't identify it. I pulled it. And my wire harness just above the fuse box started smoking. Wanted to know if someone knows the problem before I take it in to the dealer and save the cash. The dealer will charge me just to look at it. It's a ford f150. Super crew. 4.6. 2008.
Cramon101
May 9, 2013.
Everything is stocked. Haven't changed. Or touched anything.
AD
Cramon101
May 9, 2013.
We cannot see it or hear it.
It sounds like you have a harness issue. Check the headlight switch connector.
ASEMaster6371
May 10, 2013.
AD
