Mechanics
#6 CYLINDER MISFIRE
1995 Buick Riviera
Engine Performance problem
1995 Buick Riviera 6 cyl Front Wheel Drive Automatic
Engine has a misfire in #6 cylinder. Has new spark plugs, wires, swaped #6 injector with #1 injector, no change. Also replaced the coil, and the ignition module, compression in #6 is 125 psi and # 1 is also 125 psi. No check engine light and voltage to all injectors is 14.63
Winzat13
April 14, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
