My car starts up then dies out immediatly. It is a 3800 supercharged V6. I replaced the camshaft sensor (the magnet is on the gear) and the crankshaft sensor. I tested the injector wires for a pulse. When the car is turning over there is a light pulse on each injector. Once the engine starts, the pulse stops, then the engine dies and the test light pulses once. If I introduce fuel thru the air intake I can keep the engine running, but once I stop giving it fuel, the engine dies. I did check the ecm for corrosion but it looks brand new. Any help would be good.
SPONSORED LINKS
have the same problem?
Wednesday, August 26th, 2009 AT 6:56 PM
