Images (Click to enlarge)
Mar 14, 2015 at 10:15 PM
TERENCE001
MEMBER
1 POST
Dash indicates parking lamp out.Rear taillight panel not on. I replaced all parking bulbs, front and back. All bulbs on rear panel appear to be good. I checked parking lamp fuse #20 (15amp) under the hood, it's OK.
May 14, 2019 at 12:12 PM
(Merged)
DOCFIXIT
CAR REPAIR CONTRIBUTOR
Hi
Problem likely is Body Control Module located in center console above fuse block. Find connection B1 a brown wire. With park lamps on there should be 12V there. if present then BCM is faulty if not then wiring problem..
Hope this helps
Thanks for donate
(Merged)
