fuel filter
2005 BUICK RENDEZVOUS
FATFACE1958
Engine Performance problem 6 cyl All Wheel Drive Automatic 111205 miles
Can you please tell me where the fuel filter is located I've looked along the frame and can't find
Jul 18, 2009 at 12:55 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,334 POSTS
The fuel filter is located on the frame rail on the drivers side under the drivers seat. You will need to raise the car up safely before you begin.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here is a guide that will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Here are some diagrams (below) of what it will be like on your car
Cheers, Ken
Oct 12, 2017 at 12:07 PM
DALE SCHNEIDER
Engine cuts out when I step on throttle too hard but idles fine.
Oct 12, 2017 at 12:07 PM (Merged)
AL514
  • 5,502 POSTS
a Fuel pressure test should be done first to see if you are getting a drop in pressure under heavy throttle. And also scan the ECM for trouble codes. even if the check light isn't on right now. let us know what you find. This could be a sensor issue too
RENEE L
  • 1,260 POSTS
Hi DALE,
If you decide to check the fuel pressure yourself here is a link to an article from this site that features written instructions and pictures showing and explaining the process of checking the fuel pressure yourself. If you decide you would like do this yourself you can purchase an inexpensive fuel pressure gauge online from sites like Amazon.com.
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
MAMES
2002 Buick Rendezvous 6 cyl All Wheel Drive Automatic 198000 miles
'vehicle is "coughing" as I initially accelerate and if I give it gas slowly it runs just fine. A friend suggested changing the fuel filter. Where is it and how doI change it?
  • 110,190 POSTS
Hi:
Before you replace anything, take the car to a nationally recognized parts store and have them scan it for trouble codes. It's most likely something other than the fuel filter. The filter on this vehicle is in the gas tank. There may be an in line filter under the car aprox where the driver's seat is located along the frame. It will need unbolted from the frame.
Let me know what you find.
MELNICKELL
2003 Buick Rendezvous 6 cyl All Wheel Drive Automatic 124000 miles
I was wondering where the fuel filter is located on buick rendezous.
Thank you
Melissa
Oct 12, 2017 at 12:08 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel filter is located on the frame rail near the tank, under vehicle.
