fuel filter
2002 BUICK REGAL
75,000 MILES • 6 CYL • FWD • AUTOMATIC
UNHANDYDANDY
Can you please tell me exactly where the fuel filter is located? THANKS
Jul 6, 2010 at 5:52 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Under vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line here is a guide that will walk you through the service
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jul 6, 2010 at 5:58 PM
CHRISCALE
Where is the fuel filter located in the engine compartment? Or is it an in the tank fuel filter?
May 23, 2019 at 6:37 PM (Merged)
DANIELLE_BOYD1620
The fuel filter is located under the car on the left side near the fuel tank here is a guide and diagrams below to help you get the filter changed out.
Cheers
MELINDA.FATANI
Engine Mechanical problem
1998 Buick Regal All Wheel Drive Automatic 93000 miles
Where is the fuel filter located and how can I check to see if it needs to be replaced?
  • 110,190 POSTS
check near the fuel tank or along the fuel rail. Fuel filters should be replaced aprox every 30K. You can check fuel pump pressure before and after the filter to know if it is plugged.
