2CarPros - Car Questions & Answers
1996 Buick Regal Repair Question
Topics covered: Engine, Spark, Coil pack.
Asked on August 28, 2009
1996 Buick Regal hard start hot
Engine Performance problem
1996 Buick Regal 6 cyl Front Wheel Drive Automatic 158000 miles
car starts and runs fine even hot but once it's shut off hot won't restart for 15 minutes
Avatar Asked by Mercyalone
Answer
Replied on August 28, 2009
Next time don't wait 15mins. Do below immediately to catch it.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tiny Answered by rasmataz
68 questions asked
