1991 Buick Regal Repair Question
Topics covered: Sensor, Camshaft, Compression.
Asked on January 10, 2009
1991 Buick Regal engine wont start has fire,fuel,compressio
Engine Mechanical problem
1991 Buick Regal 3.8 6 cyl TPI Front Wheel Drive Automatic 105657 miles
My car turns over has spark, fuel and compression and still will not start. Car is fouling plugs with so much fuel that it is getting into the crankcase. Replaced coolant sensor,crankshaft sensor,& camshaft sensor. The fuel pressure regulator isn't leaking, but could it be the problem or do you have any ideals of what the problem could be?
Answer
Replied on January 10, 2009
sounds like you are not getting any air now, make sure your fuel filter is clean and you do not have any air restrictions. get back to me
