2CarPros - Car Questions & Answers
1996 Buick Park Avenue Repair Question
Topics covered: Fuse, Door, Door lock.
Asked on April 8, 2008
1996 Buick Park Avenue LOCATION OF FUSE & RELAY PANEL F
Procedure and location of the fuse block/relay for the power door locks and power trunk motor. Owner's manual states that these are located on the passenger side behind the front kick panel.
Experience, a diagram, or both would help keep the amount of broken plastic parts to a minimum.
Avatar Asked by skewedboy
Answer
Replied on April 20, 2008
If you have no power door locks, power trunk, or fuel door release - then the problem is most likely a 20 amp fuse located behind the carpet on the passenger kickpanel. Remove the black underdash facia so it hangs down (no need to undo the far left one), unscrew the plastic trim from the sill to the A-pillar, fuse box is held by two snaps at bottom and the wiring at the top as far as I could tell. Pull on fuse/relay centre twisting to provide better visiblity. Fuse is somewhere near the upper left position, check your owners manual.
Tiny Answered by boneheaded
0 questions asked
