Engine will not start
2000 BUICK LESABRE
6 CYL • 2WD • AUTOMATIC
RABBOTT
Engine will turn over but no start seems like it has fuel pressure ,some anyway i dont think it is getting spark, any thoughts?
Nov 18, 2010 at 11:20 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
It sounds like you have a cranks angle sensor that is out. Here is a guide to help you see what you are in for when replacing the sensor:
Check out the diagrams (below)
Cheers
Nov 19, 2010 at 12:34 AM
THOR68372ROCKON
I would first see if it stored any codes in the computer.(CODE SCAN)Depending on what code it threw out, it can tell you what to look at next(short cut)Pull A Spark Plug Out, Does not Matter Which One. Put Plug wire back on spark plug, touch threaded part of Spark plug to head or metal bracket, hold with rubber insulated pliers, have someone turn engine over and watch for a spark at tip of spark plug. If there is spark, you just ruled out fire, now on to the fuel. you will need a fuel pressure tester to test the fuel pressure at the fuel pressure regulator (Rent at Advance Auto I Think)Check your Specifications in a chiltons manual for correct fuel pressure at regulator. If no Pressure or LOW pressure I Would probably look at the fuel pump (1st Check Fuse or relay). I would say check fuel filter but never in my 27 yrs. wrench turning have I ran across one so bad it would not start.
Sep 1, 2011 at 2:51 AM
JUSTTHINKIN
In case you have tried everything else:
I have a 2000 Buick Le Sabre. I replaced alternator and pulled some fuses and engine would crank, and occasionally start for a revolution or two, but that was it. No start. No code thrown. Security light not flashing.
Checked fuel pressure its okay!
This guide will help you
Then I noticed the two of the three screws in the forward fuse holder were loose. I tightened those and instant start. The screws secure the big connectors below. When the screws loosened, pulling a fuse was just enough for connectors below to loose contact. Still no start, Then I replaced the crankshaft sensor and BAM! the engine started.
Thanks 2Carpros
Nov 4, 2015 at 10:20 AM
FOLDERQUEEN
Other Category problem
2000 Buick Lesabre Engine Size unknown Wheel Drive Type unknown Automatic 116000 miles
For a while the service engine light has been on. I was planning on taking it into the shop this next week to have it checked out. Last Monday, the car wouldn't start. I jiggled the thing (maybe it's called the ignition switch) where you put the key in and it finally started. Worked fine for 5 days and then the same problem happened yesterday, but won't start even when I jiggle the switch. I tried to jump start it from another vehicle, but nothing happens. The lights, horn, radio seem to be working fine. Do you have any idea what the problem could be?
Jan 6, 2020 at 12:51 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
[quote:e1b62fabc2="folderqueen"]Other Category problem
For a while the service engine light has been on. I was planning on taking it into the shop this next week to have it checked out. Last Monday, the car wouldn't start. I jiggled the thing (maybe it's called the ignition switch) where you put the key in and it finally started. Worked fine for 5 days and then the same problem happened yesterday, but won't start even when I jiggle the switch. I tried to jump start it from another vehicle, but nothing happens. The lights, horn, radio seem to be working fine. Do you have any idea what the problem could be?[/quote:e1b62fabc2]
you may need a new ignition switch
you should have it looked at
SHOKAZE
Electrical problem
2000 Buick Lesabre 6 cyl Front Wheel Drive Automatic
My car wouldn't start the other day, and every time i try to start it the lights would come on but the engine wont turn over, the relays click but the enigine wont start
RACEFAN966
  • 5,029 POSTS
So when you say it won't start do you mean it cranks over and won't start or it just won't crank over. Get back to me and lets go from there.
POPPTUNA
Engine cranks but no spark,no injector pulse, no rpm.Fuel pressure is about 48lbs
JERRYGOODWRENCH
  • 77 POSTS
check out the crank sensor or th ign module or possibly the cam sensor if it has one..Good luck. Let me know
TBRONCA
First for about 6 weeks, my 2000 lesabre would stall and then in about 0 to 5 minutes, it would start back up. It would only do this once per trip. After it stalled and started back up it would run fine until the engine was turned off and then it would stall again during the next trip.
Now the engine would hardly turn over. Tried again and it started. Drove for about 10 minutes and stopped. It started again and the engine had a light grinding noise (like an alternater grinding) for about 5 minutes and then it stalled. After the engine was turned off some motor was running under the engine towards the front of the car. It was smoking and finally stopped running.
MERLIN2021
  • 17,250 POSTS
The motor towards the front of the engine may be the cooling fan, test it, but if it was smoking, replace it, test charging system, was it cranking slow? Or not doing anything? Was the check engine light ever on? Did the engine overheat? The motor you heard running, was it the cooling fan motor? Where was the smoke coming from?
https://www.2carpros.com/how_to/how_to_test_alternator.htm
https://www.2carpros.com/how_to/battery.htm
BRUCE DOWNS
the car wont start after setting a couple of days Acts like the battery is low. Had the elect. system and battery checked out and they could find no problem. said the problem may be I dont drive enough to keep it charged. so I tried starting it every other day and I still have the problem.
it does nothing at all and will not crank untill jumped then starts normally
What is it doing? -cranking over and will not start or just won't crank at all/nothing-
SHORTY1187
Engine Performance problem
the car has been running fine but was started and all of the sudden started to run rough. it was shut off and would not start back. what was thought to be smoke was noticed in the engine comparment. i checked to see if the engine was getting fuel and the pressure was 60 psi at the manifold. i removed a plug to check for fire. there was none (i don't think i had it grounded good) so i removed the ingnition module. it tested bad at the parts store so i replaced. the engine would still turn over but would not even try to start. i took the new module back to the parts store (just in case) it tested good. still believing i was not getting fire i replaced the crank shaft sensor. still have the same problem. i removed a plug again and found that the plugs were firing. i checked them all. i then thought that it had jumped time, since it had 200,000 miles on it. i tore it down and guess what that was not it. i replaced it anyway. while i was at it i replaced the camshaft sensor. still had the same thing. oh, i forgot to mention that i used a scanner and no code was shown. i installed new plugs and plug wires. plus i had all the coils checked. i had the batt checked, cleaned cables, checked fuses and relays and nothing found. then today i took the catalytic converter lose and cranked the engine. i heard a sound which sounded like a backfire which i heard one time before, during this whole process. this time i saw what seemed like smoke in the engine comparment but i couldn't smell anything. the smoke all most seemed like a mist. the battery was going down so i put everything back together and went home with my tail between my legs. my dad (who the car belongs to) put a charger on the battery. two hours later he calls me and tells me the car started. he cranked it with the pedal to the floor and it started. the car ran fine for a minute and then seem to start to surge. it choked down a quit. it started back and did about the same thing, it would only stay running if we kept giving it gas. i pulled a plug which kind of looked strange. while the car was running there was white smoke coming from the tailpipe. i'm wondering now if the problem may be with the intake or a head gasket? there is no water in the oil. please help
MMPRINCE4000
  • 8,548 POSTS
If you are getting white smoke out the exhaust that has a sweet smell to it then it is coolant.
I would start by running a compression test on all cylinders, they should all be within 10%. If compression is OK, then perform a cooling system pressure test to check for an intake gasket.
GM had many problems with the V6 engine's intake manifold gasket.
KMORELAND9
My 2000 lesabre doesn't start. The starter turns but it won't turn over and start. What could the problem be?
JDL
  • 16,098 POSTS
Welcome to the forum. How long since a tune-up? If it cranks good but won't start, have a helper crank it, while you check for spark at the plugs. Use a gage and check fuel pressure. Some of the national brand autostores might loan you a fuel pressure gage. You can call and ask.
To check for spark at the plugs, you can pull a spark plug boot. Stick known good plug or spark tester in the boot. Ground metal part of plug against metal part of engine. Have helper crank the engine, watch for spark at the tip of spark plug or tester.
JAJAMES
car runs and starts great. When I drive for 20 + miles, turn car off for a few minutes, ie to run into a store, come back out, car idles low/ rough for a minute or so then dies. Then car won't start for at least 1 hour or more. Car cranks, but wont turn over. When car has time to cool off, so to speak, it start up with no problem. It is not showing any codes. Volt meter reads 14.6 and thermostat is not running hot. Any ideas?
Next time it stalls don't wait do below immediately to determine if its fuel or spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
DELTADIVER
2000 Buick LeSabre Limited electrical problem
This is an intermittent problem which occurs when vehicle is in motion or idling while parked.
The warning lights come on, the fuel gauge falls to empty, the radio goes off. The DIC mileage information lights go from numerals to dashes.
also, the air conditioning stops cooling.
When parked and put in park the doors will not unlock and the keyless entry fobs will not unlock the doors or the trunk.
During this condition, the car will not start or even make a sound as if it were getting power to the starter.
The battery is good and I have cleaned the terminals good including the ones under the hood.
While idling during this condition, I can slam the trunk or a door and all will return to normal-some of the time.
The condition does not affect the driving of the car.
I think this could be the body control module(?) What do you think? Is this located under rear window deck?
Jan 6, 2020 at 12:52 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
Have BCM scanned for "B" codes to start with.
I would also remove battery and have it tested at most autoparts stores for free.
Battery can read 12V but still be bad.
If battery is over 4 years old, I would suspect it first.
EZPOCKTS1
I have a 2000 buick lesabre and it just started stalling. I can start the car it will run for about 10 seconds then die. Or if it does stay running when i hit the gas it seems to lose power ( lights dim motor bogs down) its sounds horrible too the whole car shakes. I did get it to drive once but it when i step on the accelorator it has a****** rev where it wants to go then bogs down wants to go then bogs down. I have tested the fuel pressure its at 43 psi replaced the fuel filter tried the fix for the engine being flooded replaced the battery. Help please
Check and test the idle air control valve, TPS and MAF sensor-
JLM123
My car is not starting correctly. I was able to jump it, let it run for twenty minutes or more, and then shut it off. It started, but barely. I let the car sit for another hour and it would not start. About a month prior to this problem I had to have my headlights replaced (unrelated?). Is this a battery problem or something more significant?
WRENCHTECH
  • 20,761 POSTS
Sounds like a bad battery. That should be the first thing you are testing.
WKCOLEMAN
My Buick LeSabre will not start up. The starter is turning the engine just fine but the engine will not start up. It has been to 2 different mechanics and runs for a couple of weeks the first time and then just 3-4 days the second time. The mass air flow
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
JOHNNYD123
I have a 2000 buick lesabre and a few days ago I was driving it just fine, then I take it home and park it in my garage. Next morning it won't start! When I go to turn the key, it will turn over but not start. Just replaced the fuel pump about a year ago and when I turn the key to on I usually wait for the sound of the fuel pump to turn on and all I hear is a click from the relay under the back seat. So I don't know if it could be a bad fuel pump, bad starter, bad alternator, or a bad battery. Any suggestions?
HMAC300
  • 48,601 POSTS
scan for codes and check fuelpressure first with a gauge, doesn't sound like a battery. auto parts rent gauge 48 psi minimum
LWELLER62056
Had trouble starting then I shut it off and it sounded like it was still running after I took the key out. Then I smelled like electrical burning smell and finally I unplugged the battery to stop it. What can it be starter? ignition switch? not sure what to get for it :(
WRENCHTECH
  • 20,761 POSTS
Sure, it can be either of those things or a few others also. Remove the purple wire from the starter and see if it still does is. If yes, it was the starter. If not, the problem is elsewhere in the circuit and you will have to follow a wiring diagram to troubleshoot it.
BASSN T-VILLE
  • 8 POSTS
When you turn the engine over, it sounds like it is trying but it will not catch. There are no codes.
I have fuel pressure at the rail. I checked all 3 coil packs (Very close together on ohms readings and within spec's). I had Auto Zone check the ECM 3 times and it passed every time. I suspect the crank position sensor is bad but don't want to remove the harmonic balance unless I am sure.
If that is it, would I be better off changing the camshaft position sensor while I am "n the area"?
HMAC300
  • 48,601 POSTS
try resetting security system first see pic
BASSN T-VILLE
  • 8 POSTS
HMAC300: THANX for the quick response! I will try that tomorrow night, However, I have a question? The pic says the theft light will shut off after 10 minutes AND the whole process has to be repeated 3 times within 30 minutes. If everything works right, the whole process repeated 3 times adds up to about 31 minutes.
HMAC300
  • 48,601 POSTS
I didn't create the instructions just passing them on . you can do it once it may start but if the second time the light goes out time is diminished
BASSN T-VILLE
  • 8 POSTS
Sorry, I didn't mean anything by that. I know you are just passing it along. I will try it tomorrow, all 3 times if need be. I will let you know what happens.
DONNA BROWN BROOKS
Car will not start no radio, but all the light on the dash door will not work power window will not work and it is saying unknown driver.
BASSN T-VILLE
  • 8 POSTS
HMAC: Tried the reset tonight. Didn't make a difference. I did discover that that might be a typo. The light went off after about 10 seconds. I even went through twice to make sure.
It looks like I will try the sensor tomorrow night.
HMAC300
  • 48,601 POSTS
try resetting security system on car if no owners manual look online for your car. but from sounds of this it is going to need a trip to repair shop and scanned for codes.
BASSN T-VILLE
  • 8 POSTS
UPDATE:
I replaced both the cam & crankshaft sensor. No change.
It does backfire through the throttle body so I am thinking timing. Could the timing chain jumped?
Or, could it have blown out a sensor (MAS, TPS, etc...) the 1st time it did it?
ANY suggestion would help!!!
