Engine will not crank over?
1997 BUICK LESABRE
189,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JONATHAN GORDON
I turned it off the other day and it would not start back up. It will not crank over I turn the key on the lights on the dash cam on the gauges work security light is blinking has blank since I own the car. But when I turn the key nothing happens I have with the car set four days or so and went out and got in and started right up this is not the first time this is happened but I want to fix it so don't happen again.what are your thoughts? The battery is good but starter is good, fuses are all good. where do I go from there?
Dec 28, 2018 at 2:44 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,346 POSTS
I would do a security system relearn which you can do by following this guide.
https://www.2carpros.com/articles/how-to-reset-a-security-system
this guide can help as well
Dec 30, 2018 at 12:00 PM
TISHTRISH
Engine Mechanical problem
1997 Buick Lesabre 6 cyl Automatic 67,000 miles
My husband went down to the store when he came out to try to start the car, It wouldn't start. We figured that it was the starter, so he replaced that, but still won't start. When you turn the key to the start position all the lights come on and the radio,ac etc. What could this problem be?
Aug 6, 2020 at 9:37 AM (Merged)
Pick your symptom:
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada when key is engage to starting position
Could be the starter,starter relay,park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
TISHTRISH
We are now thinking it might be that the security system got tripped..Because the security light blinks when you try starting the car..Have you ever heard of this before?
TISHTRISH
I found out that the problem was that a wire snapped on the lock solenoid.
OFFWORLD
  • 8 POSTS
Car won't start. Engine does not turn. No clicking sounds from starter (possibly one click when ignition is turned). Battery is old but seems good. Lights are bright and do NOT dim when ignition is turned. Tried starting with battery charger/boost 30amp on .... still no start. Over the past month, noticed delay between turning ignition and starter engaging. Instead of starting immediately, it seemed to take a second or two before the starter responded. Hard to recall, but it seems delay became slightly longer over time.
#1. Where is the starter located on this engine ... front towards the radiator, or rear towards the cabin?
#2. How do I determine it's definitely the starter? I have a volt-ohm meter. What does bridging the connections on the solenoid do? How do I test/eliminate the ignition switch and neutral safety switch?
Thanks
Jack
jturner4@hotmail.com
BMRFIXIT
  • 19,053 POSTS
[quote:0fdbdcb024="offworld"]Electrical problem
1997 Buick Lesabre 6 cyl Two Wheel Drive Automatic 80,000 miles
Thanks
Jack
jturner4@hotmail.com[/quote:0fdbdcb024]
Starter front by radiator
has two terminals on it large and small
big one has to have battery volts at all times
also the small wire should have battery volts only when you try to start
if u jump the two terminals together the starter should activate
and turn the engine
also check your fluids
oil and coolant
let me know
OFFWORLD
  • 8 POSTS
OK, removed plastic skid shield and see starter. Seems doable. There appears to be a plastic shield/cradle under the starter that needs to be removed before I can get to one of the bolts. I made a connection between the small wire solenoid connector and the + battery connection ..... the starter turned. What, if anything, does that prove?
How do I test to see if the ignition switch or neutral safety switch are NOT the problem before I go pulling out the starter? I'm guessing I connect the volt meter to the small solenoid wire and turn on the ignition, but I'm a little fuzzy on the + - connections and the reading I'm supposed to get.
Thanks for your help,
Jack
BMRFIXIT
  • 19,053 POSTS
[quote:320f2c3a96="offworld"]OK, removed plastic skid shield and see starter. Seems doable. There appears to be a plastic shield/cradle under the starter that needs to be removed before I can get to one of the bolts. I made a connection between the small wire solenoid connector and the + battery connection ..... the starter turned. What, if anything, does that prove?
Jack
jturner4@hotmail.com[/quote:320f2c3a96]
when you made the connection and starter turn that tells the starter may be OK
so we need to find why if any the signal not reaching the starter from the ignition switch
so with a volts meter black lead on the ground (_)
and the red lead on the small starter terminal
try to crank you should have battery volts
if no volts look at the top of the tranny for a plug with 4or 5 wires
unplug it and with the red lead check if you have a battery volts when starting
you should on one wire
if you do you need the N/S switch
let me know
OFFWORLD
  • 8 POSTS
Will check it out tomorrow. I'm doing this on my own, so I need to run wires from the solenoid to my meter leads so I can read it when turning on ignition. I'm using solid 12 gauge wire. Tried it earlier today, got a zero reading volts on the meter. Not 100% sure my connections were tight .... will try again.
Unclear on testing the neutral switch. I think I found it ... passenger side, near cabin, looking down near the brake master cylinder. 2 connectors, one with 4 or 5 wires and another connector with 7 wires. looks like 2 bolts connecting it to transmission and a linkage on top. What do I disconnect, _where_ do I put + lead, and what does it mean voltage/no voltage?
BTW, disconnected battery earlier today. Now have SECURITY blinking when ignition is turned to ON. Is this a problem that will prevent STARTING? How do I reset SECURITY?
Thanks
Jack
BMRFIXIT
  • 19,053 POSTS
[quote:c6054d6f9a="offworld"]Will check it out tomorrow. I'm doing this on my own, so I need to run wires from the solenoid to my meter leads so I can read it when turning on ignition. I'm using solid 12 gauge wire. Tried it earlier today, got a zero reading volts on the meter. Not 100% sure my connections were tight .... will try again.
Thanks
Jack
jturner4@hotmail.com[/quote:c6054d6f9a]
I always found it easier to use a test light instead of the volts meter
you right on the N/S switch location if you need wiring let me know
security : turn key on attempt to start and leave key on for about 10 min the security light stop blinking
key off you may have to do it 3 times over
good luck let me know
OFFWORLD
  • 8 POSTS
Connected about 36" 12 gauge solid wire to small solenoid cable. Attached volt meter. Turned ignition switch, got a reading of (negative) -0.03. Got similar reading in neutral, and by just applying brakes with ignition off. Turned on 30amp battery booster and tried again. Turned ignition on and got a positive reading of +0.07. Tested with test light (ignition on) .... no light. Can I assume the solenoid is not getting power and my problem is either the neutral switch or ignition switch? How do I test the neutral switch? I've removed the 2 connectors, but need guidance on which leads I test.
https://images.2carpros.com/forum/automotive_pictures/86488_neutralB_1.jpg
https://images.2carpros.com/forum/automotive_pictures/86488_neutralA_1.jpg
Thanks for your help, Jack jturner4@hotmail.com
TUTY2386
i have a 97 buick lesabre 3800 133000 miles the car turns on when itcold but when i drive it for a while it will not start it feels like the battery is dead and it doesn't send enough power to the stater. i changed the starter, battery, and alternator and it still does the same thing i will not even crank, it only cranks in the morning and real weak. i tested the battery and it's good what can it be?
BMRFIXIT
  • 19,053 POSTS
before we go any further do you still have security light on and blinking
IMPALASS
  • 3,112 POSTS
Hello –
First to better assist you, is the 8th digit of your VIN K and is this a Lesabre Custom or Limited?
So you and I are saying the same thing I need to ask a couple of questions.
When you say it turns on when it is cold…….are you saying – when you turn the key to start it, the engine turns over just fine. Nice and strong, no odd noises, starts right up.
Once you drive it and go to start it – you turn the key to start it but it acts like the battery is dead and the engine barely turns over – really slow?
So then do you jump start it and it starts up just fine with jumper cables or you have to wait a while?
Have you tried jumping it with cables when it does this and if so what does it do?
After you changed the battery, alternator and starter you said it won’t crank. Now does this mean you turn the key and it is totally dead….no noise, no engine turning over or does this mean you turn the key and the motor turns but it doesn’t start?
I know you tested the battery but do me a favor…..first thing in the morning based off what you say. Please go to Auto Zone or O’Reilly’s and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter. This is important as they can check all together to see how they are working together.
When was the last time you did a tune up….plugs, wires, fuel filter?
We don’t need to do a fuel pressure check yet based off of your code, but we may need to later.
Please do the above and provide the information requested and we can take it from there.
OFFWORLD
  • 8 POSTS
Yes, SECURITY light is still blinking. Should I have fixed that before testing the solenoid connection? Does SECURITY block the power?
If I leave the key ON for 10 minutes, won't that run down the battery (lights are always on when the key is ON).
_Jack_
TUTY2386
the car turns on in the morning but real week after i drive it the motor turns and then it just stops turning i tried jumping it and it doesnt do anything i got stuck in autozone when i took the battery to get checked and they said battery is good and the only sensors that show bad are the mass flow sensor and the 02 sensor and now the car doesnt turn on the last time i gave it a tune up was 5 months ago when i changed the control module
BMRFIXIT
  • 19,053 POSTS
[quote:47128afead="offworld"]before we go any further
_Jack_[/quote:47128afead]
put every thing back
and let s get the security issue solved 1st
do u have a chip on the ignition key
if so do you have a different key that you can use lets try that
leaving the key on for ten min may not work on your car sorry I was thinking different system
check all the fuses with key on and with key off
check fuse # 7 located behind right side of dash
check air back /vats fuse left side
clean the key and the ignition cylinder
IMPALASS
  • 3,112 POSTS
hello – tuty2386
so i can make sure i am giving you the best possible service and help, i really need you to answer my questions in the way that i ask them. the big problem is i am not there to see, hear, or feel, all the things the car is doing. since you and i look at things different and use different words for different things….we need to get to where we are saying the same thing. that way i can help you better. i don’t want to let you down here. i also ask questions in a certain way to help me better understand what the car is doing in certain situations and how all the components are working together. that is another reason i need them answered the way i ask. also, i am referring to technical manuals so some of the information is to work through those to again, provide you with the info you need. so i am sorry i am not understanding certain things you say, so if you could help me that would be great.
let’s kind of review - you can actually copy and paste my questions and then answer them underneath.
first to better assist you, is the 8th digit of your vin k and is this a le sabre a custom or limited?
on you first and last post – i am probably looking at it wrong, but it looks like you are telling me something different for the morning start. i am going to copy your posts and ask my questions at different spots. all you have to do is answer after my questions. what i did if you notice next to what you said i put “tuty2386---“ that way you will know this is what you said and what i am asking or saying is underneath each area.
tuty2386---i have a 97 buick lesabre 3800 133000 miles the car turns on when itcold
you turn the key to start the car and the engine turns over and starts first thing in the morning. right?
does the engine sound good and strong?
tuty2386---but when i drive it for a while it will not start it feels like the battery is dead and it doesn't send enough power to the stater.
after you drove it and it was warm, you shut it off to do something. when you tried to start it, you turned the key to start it, the motor turned over really slow like the battery was dead and the car never started. right?
tuty2386--- i changed the starter, battery, and alternator and it still does the same thing.
by the same thing, you turn the key, the motor turns over really slow and never starts?
or, you turn the key, the motor turns over normal speed but never starts?
why did you change the battery, alternator and starter at the same time?
did someone check them out and tell you they were all 3 bad?
tuty2386--- i will not even crank,
do you mean, you turn the key and the dash lights come on but there is not noise?
the engine does not turn over at all.
tuty2386---it only cranks in the morning and real weak.
if you answered the questions above, then this will be answered based off of them.
tuty2386---i tested the battery and it's good what can it be?
how did you test it? did you take it out of the car and took it somewhere?
did you leave it in the car and it was tested in the car?
okay, your next post.
tuty2386---the car turns on in the morning but real week
on your first post you said it started in the morning. so now is it getting worse?
now when you turn the key to start it, the motor turns over really slow, not at normal speed?
the car does start – just the motor turns really slow when starting.
tuty2386---after i drive it the motor turns andthen it just stopsturning
you drove it, turned the key to start it, the dash lights came on, the motor turned over not at normal speed, but really slow.
then it finally stopped turning totally. there was no noise, no movement?
tuty2386---i tried jumping it and it doesnt do anything i got stuck in autozone
you tired to jump start it, you turned the key on to start it, the dash lights came on but the engine did not turn over, make any noise at all. it just sat there. dead.
how did you get it going to leave auto zone?
tuty2386---when i took the battery to get checked and they said battery is good
did you remove the battery from the car or have it checked in the car?
tuty2386---and the only sensors that show bad are the massflow sensor and the 02 sensor
okay, that’s good – we got something. that’s great! ma’am i am sorry to say you forgot to do as i requested and get the code numbers. there are thousands of code numbers. you also have about 4 o2 sensors on this model i believe. at about $65.00 each or more depending on where you buy it, lord knows we don’t want to waste any money. the code would tell me which one. is it possible to have the codes read again so you can tell me the code numbers and what they say they mean?
as for the mass flow sensor, that too can throw maybe three codes, dtc p0101, dtc p0102, or dtc p0103. now, this sensor can be easily contaminated causing hard starting, rough idle, hesitation and stalling problems. so to me, change it.
tuty2386---and now the car doesnt turn
do you mean, you turn the key, the dash lights come on and everything is dead. no noise, the motor doesn’t spin, turn over at all?
tuty2386---on the last time i gave it a tune up was 5 months ago
what did you do for your tune up? did you change the plugs, wires, air filter, fuel fileter? what exactly did you do?
did you do a tune up becase of this problem or it was just time?
tuty2386---when i changed the control module
are you talking about the ignition control module?
why did you change that?
okay ma;am….how about this. change the mass airflow sensor. auto zone has them.
while there picking up the sensor, i think the car is drivable – yes? if so, i know you tested the battery but do me a favor…..first thing in the morning based off what you say. please go to auto zone and for free they can bring their tester out and check your battery, alternator and starter. this is important as they can check all together to see how they are working together while they are in the car.
also, very important - for free they can pull the codes to the car. most important: once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. example, if the code was e0568 o2 sensor bad. then make sure you give us all of that.
then, answer all my questions as best as possible the way i asked them.
thanks for working with me on this
OFFWORLD
  • 8 POSTS
Yes, there is a chip on the key.
Yes, I have a second key. I tried it earlier, but possibly after the SECURITY problem.
I checked the IGN SWC fuses (60 amp) earlier, they looked OK.
My fuses are under hood on firewall. 2 boxes of 6-8 fuses each. Plus 5 or 6 large square (relays?) below.
Do I have more fuses inside the car?
What is fuse #7?
What is air back /vats fuse left side?
Is this SECURITY thing fixable?
_Jack_
Aug 6, 2020 at 9:38 AM (Merged)
TUTY2386
THANK YOU FOR EVERYTHING I FIXED THE PROBLEM THEY SOLD ME A BAD STARTER I GOT A NEW ONE PUT IN AND THE CAR IS WORKING FINE
BMRFIXIT
  • 19,053 POSTS
[quote:7805e2740d="offworld"]put every thing back
What is fuse #7?
_Jack_[/quote:7805e2740d]
its possible
did you check your PM i sent you one !!!let me know
its AIRBAG/VATS fuse
i think you should have fuses on the inside under dash and under /around the clove box area
IMPALASS
  • 3,112 POSTS
That’s great Ma’am
For my info….how did you find out it was a bad starter??
G41075
I bought this car about a month ago. It's a 97 Buick Lesaber with 45,000 miles and remote start. Seems to be very well taken care of. Was working great. 10 days ago or so my keyless entry stopped working and I assumed it was the battery. Replaced it and followed manual to program it and it still didn't work. This may have nothing to do with my problem...
Three out of the last four days the car will not start at first. At first it does NOTHING when I turn the key. After another try or two it starts making a ticking noise. Then it starts sounding like it might start and finally by the 9th or tenth try it starts. This is only the first start of the day. The rest of the day the car starts right up with no issues. I thought the remote start could have something to do with it so I stopped using it but I'm still having the problem.
The batter gage is running between 16 and 17 once it finally starts but again only on the first start of the day. After that it runs between 15 and 16.
I just don't understand why the first start of the day only. Auto Zone tested the battery and claimed it was fine. A mechanic tightened the connections to the battery thinking that may be the issue.
Please tell me what the issue is.
2CARPRO JACK
  • 11,533 POSTS
Im guessing it isnt a factory remote start? Remove it from the car, convenient I know, but they are cheap electronics and Fail quite often. Might even be the starter, have that tested too, might be drawing too much on that first start in the AM
OFFWORLD
  • 8 POSTS
Didn't know there was a PM section.
The image you sent was too small,
tried blowing it up but became unreadable.
Checked owner's manual, says I have fuses on both sides of dash (besides those under hood).
Not sure what #7 fuse is. On passenger side fuses there is a row #7 of fuses ... all empty. #1A is PASS-Key and #2E is Air Bag System, PASS-Key.
Driver side fuse #7 is Injectors.
I think I activated the security system either when I removed the negative cable, or jumped the solenoid to battery cables. Hoping to clear the SECURITY problem so I can get back to square 1.
Thanks,
Jack
TUTY2386
We had checked everything out and dicided to loosen up the starter and it started but weak so we exchanged it and the car has been turning on fine.
OFFWORLD
  • 8 POSTS
Pass-key & VAT fuses are good.
Jack
BMRFIXIT
  • 19,053 POSTS
[quote:aee253dbe6="offworld"]Pass-key & VAT fuses are good.
Jack[/quote:aee253dbe6]
check your e.mail
ELLA ZACHERY
My car won't start - won't turn over. Put in new battery - still won't start. Lights, radio, panel lights, etc. will come on. Tapped on starter, it kicks in - so it's not that. Any ideas?
2CARPRO JACK
  • 11,533 POSTS
If you tap on the starter and it works, the starter is the problem.Verify 12 volts at the small wire on the starter with the key in the crank position, if it has it, then replace the starter
KIMBERLYXBAKER
I wish yall hadnt stopped going here to communicate lol I am having similar problem with my car and am curious what your conclusion with this was.
JLMAR
97 buick lasabre ltd. sometimes will not start when ignition switch is turned on , all guages work but starter won't engage .if you wait 2-3 minutes then it will start normally . the battery , starter , alternator , neutral switch have been replaced . once and a while the security light stays on until you have driven a ways . any ideas would be appreciated .
Thank You
  • 110,190 POSTS
When this happens, you need to have a helper turn the key to the start position while you check to see if you are getting 12 volts to the smaller wire on the starter. IF you are, then the starter is most likely the problem. If not, I would move to the ignition switch. As far as the security light, that is a possible problem, but usually the system will shut the fuel pump and ignition system down, but the starter will still work.
MOSHBIKES21
  • 14 POSTS
get a new key made soon. that would be the problem. the key is getting old and bent and beet out of shape so the rollers arnt hitting perfect there for saying to the vats system wrong key and you would have to wait 3mins till securty light shuts off to try again. its a cheep fix new key with pelet about $25. should fix problem. hope i helped
  • 110,190 POSTS
THe key couldbe a problem.
ANONYMOUS
  • 0 POST
the car ran fine when i got it. then it would stop starting. i heard a "whizzing" sound from somewere in the engine. no power to windows headlights or stereo. only happened after i drove it. sometimes it would sit for hours and finally start again and other times i would have to leave it over night. brought to 3 different mechanics. no codes at all. brand new battery, new fuel filter, ran lucus fuel filter cleaner and seafoam thru it. the last mechanic said that he tested the cam sensor and the crankshaft sensor and got nothing. ran fine after that until today when i died at the bank. started up about 20 minutes later and got home. in the driveway i started it and turned it off. on the third time i heard the whizzing/scraping noise again and it stalled. wont start again. sometimes it doesnt start other times it sputters and stalls. when it sputters and i put my foot on the gas it just sputters even worse. the rpms move from about 700 to 1200 in idle and if i turn the wheel at a dead stop the battery meter goes down and lights dim. i dont know what to do with it anymore...
KHLOW2008
  • 41,814 POSTS
Check for a loose belt or bad harmonic damper for the problem when turning the steering.
You seem to have an electrical issue and somewhere a connection is not as secure as it should be which is failing intermittently.
The power windows, headlights or stereo not working indicates the problem is at the battery terminals or main fusible links. You could have a bad ground circut connection as well.
CJ MEDEVAC
  • 11,004 POSTS
THIS WAS DEFINITELY A POOR CHOICE FOR A "GET AWAY CAR" AT THE BANK!
I WAS WAITING FOR YOU TO GET "ESTABLISHED" WITH ANOTHER EXPERT, BEFORE I THREW IN MY ANSWER.....I DO NOT KNOW YOUR SPECIFIC VEHICLE, I'M MORE IN TUNE WITH OLDER, PRE-COMPUTER VEHICLES......MAINLY JEEP CJs AND OLDER FORDS
WHAT CAUGHT MY ATTENTION WAS THE "WHIZZING" NOISE YOU ARE HEARING ALONG WITH THE OTHER ELECTRICAL ISSUES....I WONDER IF THE SOUND, SOUNDS LIKE, TURNING YOUR KEY TO "START", WHILE THE ENGINE IS ALREADY RUNNING???
THEY ARE CRAMMING MORE AND MORE STUFF INTO SMALLER PLACES....PRETTY MUCH, JUST ABOUT ALL OF IT IS TOUCHING/ NEARLY TOUCHING SOMETHING ELSE
"S WIRE" (ON VEHICLES I'M FAMILIAR WITH) IS THE WIRE THAT ACTIVATES THE STARTER WHEN THE KEY IS TURNED....IT TRAVELS THRU SEVERAL SAFETY'S AND SUCH BEFORE IT REACHES THE STARTER.
ALONG THE WAY, OR EVEN WHEN IT ARRIVES AT THE STARTER, THE WIRE BE BARE, AND IT POSSIBLY/ INTERMITTENTLY TOUCHING SOMETHING SOMETHING THAT IS "FULL TIME 12V".....THIS SCENARIO WOULD ACTIVATE THE STARTER OWN IT'S OWN, WITHOUT EVEN TOUCHING THE KEY
ON STARTERS SUCH AS OLDER CHEVYS (LIKE SOME NEWER CARS) THE BATTERY AND ELECTRICAL FEEDS COME OFF OF THE "HARD TO GET TO" STARTER, THE WIRES ARE SO "GENEROUSLY" SHORT, YOU MUST INSTALL THEM IN A HARD TO SEE/ TIGHT SPOT, I HAVE SEEN THE RINGS INSTALLED ON THE WRONG POSTS (USUALLY FIGGERED OUT IMMEDIATELY)
FORD/ CJs....DO ALL OF "STARTING" AND "FEEDING THE ELECTRICAL SYSTEM" FROM UP ON THE FENDER OR FIREWALL, USING A REMOTE STARTER SOLENOID.....ONLY ONE BIG CABLE GOES DOWN TO THE STARTER......I LIKE 'EM!!!
....ON THE CHEVY TYPE SET UP
BASICALLY RING TERMINALS THAT NUTS HOLD ONTO STUDS, IF THE RING IS SET PERFECTLY ON THE STUD, CARELESSNESS IN TIGHTENING THE NUT SOMETIMES ALLOWS THE RING TERMINAL TO "TWIST" AND TOUCH/ GET NEAR THE NEXT NEARBY ELECTRIC STUD.
THESE ARE JUST SOME THOUGHTS, I THINK THAT EVERYBODY SHOULD, AT MINIMUM, HAVE ANY AND EVERY OPTION OR POSSIBILITY PRESENTED TO THEM (RIGHT OR WRONG)
AS FAR AS CHECKING CONNECTIONS---LOOK THIS OVER
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
IF THE WHIZZING IS NOT THE STARTER....IT WOULD BE NICE IF YOU HAD THE HOOD OPEN AND COULD AT LEAST PIN DOWN ABOUT THE AREA WHERE THE RACKET IS ORIGINATING FROM...IF POSSIBLE!
KEEP US POSTED
THE MEDIC
BUTCHMAIN
Engine problem
1997 Buick Lesabre V8 Front Wheel Drive Automatic 20000. miles
put in a new starter but it is still clicking & won't start
help
