Mechanics
A/C ONLY ON THE DRIVERS SIDE
1997 Buick Lesabre
Air Conditioning problem
1997 Buick LeSabre 6 cyl Two Wheel Drive Automatic 84,000 miles
When I turn on the A/C I only get semi-cool air coming out of the driver side vents. The passenger side vents blow air with the same intensity but just feels like the vents are on and not cool air.
UPDATE:
Took my car to a mechanic, had him leak check it (found a small leak at the service point), drained and re-serviced with 2lbs freon. Problem resolved. This is a tricky system because even if there's only a 1/2lb of freon present pressures still indicate the same as if the system is fully charged.
AD
Navy Ordie
June 27, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
