1995 Buick Lesabre
Electrical problem
1995 Buick Lesabre 6 cyl Two Wheel Drive Automatic
how do you check acrank shaft sensor
June 26, 2009.
Get an OBD II scan tool that will show live data. Pull up the RPM reading and crank the engine over. Hold accelerator to floor to shut off fuel to the engine. No reading find the crank sensor, inspect for damage, unplug electrical connector and clean it with electrcial contact cleaner spray and then plug the connector back into the sensor. Crank the engine while watching for RPM reading, again hold down the accelerator to prevent fuel flow to the engine. If you have RPM reading now sensor is ok, engine should run. I have seen to many Sables with just dirty connections at the crank sensor. The sensor by nature is very durable and should not fail. If you still do not see RPM you may have a internally damaged sensor or wiring problem.
Jun 26, 2009.
