security light
2004 BUICK CENTURY
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
OKMUD
2004 buick century.. security light comes on, then car wont start. wait 3 or four minutes then it starts up.
i have tried using both keys, so i dont think its that. i have remote start. Do i need a new switch?
May 25, 2011 at 5:05 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
I have found the best way to reset the system is to open the hood and lock all of the doors. Disconnect the battery for 30 minutes then reconnect the battery. Using the drivers side door unlock it using the key. This should reset the system.
Here is a guide to help as well.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Cheers, Ken
Apr 16, 2019 at 1:26 PM (Merged)
REEDEE
The security light came on last night and I need to know what this could be caused by and how much it will cost to repair
BMRFIXIT
  • 19,053 POSTS
Key would be 1st to check and ignition switch
does it still start and run for you and if so consider having it check asap
have it scanned for codes
HEROSUN
I know this is about 4 years late to help with your issue but just in case anybody else is having this issue:
My 2003 Buick Century is doing the same thing. All the lights, radio, power seats/locks/windows and all worked fine. Car wouldn't crank, just a slow click and security light is on. At first I did this http://www.youtube.com/watch?v=UWfvEouMMtcand it fixed the problem but a few months later the problem came back and this time just jiggling the wires didn't help. Was told it would be $1100.00 to replace the VATS security system in the car.
LORIST
Computer problem
2001 Buick Century 6 cyl Two Wheel Drive Automatic
We are not getting any response when we turn the key .It doesnt turn motor over.We were advised it required a New Body Control Module.We had it installed and still nothing/The security light is on and doesnt not go off
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_2001_buick_century_bcm_programing_1.jpg
When you replaced the bcm did you program it like it says in the instructions i posted?If not your going to have to do that then relearn the pass lock sensor.
BUICKOWNER39
Make: Buick
Model: Century
Year: 1998
Miliage: 183 000 kms
Engine size: 3.1L
My car has a couple of problems, first off my ABS light is always on. I don't know if it is supposed to be like that, maybe its telling you they are working I'm not sure I never had the owners manual. The "security" warning comes on periodically which I have no idea what that means but if you turn the car off and on again in usually goes away. The parking brake notification light (possibly used for something else as well I don't know) will come on once in a while, the car makes a "gurgling" noise in the engine compartment right before it happens but this light also only comes on periodically and will go away when the car is shut off then started again. And finally, there is a vibration that sounds like it is coming from the right front. You cant really feel it when you are driving, its just noise that gets worse the faster you go. It also gets worse the more you turn the steering wheel to the right but pretty much completely disappears when the steering wheel is turned to the left.
All and any help is greatly appreciated.
SDCUNEO
  • 30 POSTS
if it was the door ajar switch, that would mean that when you open the door, the interior lights and the "Door Ajar" dash light AND "chime" would not go off.
this is not the case. every door, when opened (even individually), signals the "Door Ajar" light and chime the way it's supposed to.
SDCUNEO
  • 30 POSTS
i had noticed that once before i seen that on the side that the seatbelt does work on, when you push the button on the door jamb to turn off the interior lights, it does not recall the seatbelt.
i really have no clue in to how the seatbelt knows when to retract itself?
SDCUNEO
  • 30 POSTS
yep..the door ajar light, along with the interior lights, comes on with the front passenger door ONLY open.
SDCUNEO
  • 30 POSTS
ok, so i've removed the glove box, and only to come to find out i have no idea what this "Restraint Module" looks like? and where exactly it is located? (up/down/left/right and behind the glove box?)
im not even sure what it does?
TONYD235
  • 62 POSTS
Hello: I noticed on Saturday that my security light was on and now stays on. THe car starts fine and it runs good. Will that security light cause me any trouble?
SDCUNEO
  • 30 POSTS
ok, just to make sure about this so i dont do anything that i will soon regret.
i found a black box behind and mounted above my glove box, and what looked to be, i think, 2 connectors with, what i think is, about 8 wires on each connector. one connector is grey, and the other is black.
i just want to make sure that this is infact the restraint module? and that i disconnect and reconnect both or either or the connectors?
as i had noticed that when i found it, i was looking back in there and poking around just a bit with my hands, that when i started my car, the seat belt light on my dash was flashing. normally, that light just stays on instead of flashing when my lap belt isn't fastened. and even then it goes off after a little bit.
but this light just keeps flashing no matter what. and i have noticed that when i open (any) door(s) when its running, it goes off and once the door is closed, it goes back on flashing again. so there's gotta be some kind of connection between all this right?
DJCL
  • 767 POSTS
The pass lock sensor might be going bad. I would check the body module for codes
SDCUNEO
  • 30 POSTS
i got the placement screws off of it, and when i disconnected the 2 connectors, the seatbelt light quit flashing alltogether.
also, the driver side seatbelt (which does work) didn't move when the it's door was opened/closed.
but i did disconnect and reconnect both of them and the passenger auto seatbelt still does not work.
and all the wires do infact look to be fully seated into the connecter and looks like it should be functional.
i guess this means the module is bad?
and if it is, where in the world would i find another one?
TONYD235
  • 62 POSTS
Thank you!!
SDCUNEO
  • 30 POSTS
alrighty, thanks a bunch!
  • 110,190 POSTS
Don't wait too long to check that. It could refuse to start.
SDCUNEO
  • 30 POSTS
well, i took a ride to a junkyard and found the exact part that matches it exactly, and replaced it and hooked it up only to find out that it still doesn't work. the driver side still works but the passenger side still does not work.
SDCUNEO
  • 30 POSTS
that sounds like it very well could be the culprit.
when i first got the car, i pulled both of those levers, trying them out, etc.. and nothing happened with either of the seatbelts.
and i really need to clean down there anyway, seeing how theres a bunch of coins and old food, and who knows what else!
SDCUNEO
  • 30 POSTS
alright, after a bit of menuevering and a lot of time, i got the center console out and took a look down in there. I disconnected the wire the the red light that comes on on the console when the lever is raised. and disconnected this other wire what looked like it came from the lever mechanism.
anyway, long story short, i reconnected those 2 wires, sprayed some wd-40 on the mechanism and a few other places as well (it couldn't huirt) and reassembled the console and yet again, only to find out that it still didn't do anything for the seatbelt.
one other thing, i tested both of the levers after i was done, and, just like before, neither of the seatbelts were phased by the levers.
RC9896
It just popped on when I started the car. The car ran fine. I turned it off and on about 4x and it started each time fine.
SDCUNEO
  • 30 POSTS
i know what you're talkin about, but i'm not sure on how to check to make sure they are working.
but are you sure that it's not possible that when the a.c. was worked on, that a wire may have been cut or disconnected and never reconnected? i mean, after taking all that apart, i've seen the different parts and where the wires are routed through. and so far you've helped me troubleshoot everything. and the only thing i can see that's left is the wiring. and if i take out the dash, and see that it's not the wiring, i don't know whether to just forget about it or take it to a shop.
SATURNTECH9
  • 30,869 POSTS
you have a factory security system i posted a description of how it works.
SDCUNEO
  • 30 POSTS
yeah i did that. I haven't done anything that you haven't told me.
I was talking about my grandma had the a.c. worked on and they took out the dash to do it. This was a few years before I even got this car.
RC9896
Thank you. What do I need to do now? Purchase another key? My spare key that I've never used since I got the car 5 years ago didn't help. The light was still on. Am I not going to be able to start my car eventually?
SDCUNEO
  • 30 POSTS
well i do, just not much, lol.
now what exactly is the "A-pillar trim"?
SATURNTECH9
  • 30,869 POSTS
The most common reason is the wire going to the ignition cylinder breaking.
SDCUNEO
  • 30 POSTS
if im interpreting thins correctly, then what it is, is actually not the dash. it's just a part of the interior trim?
and if that's so..then that means, i've taken that off plenty of times before. that thing just reveals the track in which the seatbelt is guided through.
SATURNTECH9
  • 30,869 POSTS
I posted trouble shooting for your issue let me know what you find.
