Mechanics
DIMMER SWITCH REPLACEMENT
2003 Buick Century
Electrical problem
2003 Buick Century 6 cyl Front Wheel Drive
The high beam side of my dimmer switch has gone out and I am trying to replace the dimmer switch. I have removed all the panels except for the panels around the column. The top panel is binding between the steering wheel and dash panel cluster. I have all the molding removed around the cluster. Is there another piece that needs to be removed to be able to get the top and bottom panels off from around the column? Also, is there any special tricks to removing the dimmer that would be helpful? Thanks
Tightwads
February 22, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
