Codes
1999 BUICK CENTURY
117,000 MILES • 6 CYL • FWD • AUTOMATIC
CLUMCRAZY
How do I reset "Service Engine Soon" Light
Nov 24, 2010 at 2:41 AM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
An OBDII reader or scanner should be used to erase the codes and reset the PCM
disconnecting the battery would erase the codes too and all the PCM memory as you may or may NOT end up with a rough idle and stalling until drive cycle is completed
Nov 24, 2010 at 2:46 AM
PAUL RAPOSO
Computer problem
1999 Buick Century 6 cyl Front Wheel Drive Automatic
The "Service Engine Soon" turned on in my 99 Buick Century. I went to my usual mechanic and he checked the system with the code reader and told me it the same problem I had 2 years ago--the gas cap was loose. He suggested Ii buy a new one. He then cleared the code and the light was not on anymore.
I bought a new gas cap from the dealership and it fit fine. Now when I start my car, the SES light will turn off immediately, while all the other lights stay on a few seconds before turning off. If I turn the car on without starting it, all the lights come on and while the other lights will turn off after a few seconds, the SES light stays on. Is this all normal?
Jan 6, 2020 at 4:24 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Yes that is normal.As long as they go out it is all good
PAUL RAPOSO
[quote:ef0869c331="2CarPro Jack"]Yes that is normal.As long as they go out it is all good[/quote:ef0869c331]
Hi Jack, Thanks for the reply! Good to know everything is as it should be.
Jan 6, 2020 at 4:25 PM (Merged)
CMITCHEL
Engine Performance problem
1999 Buick Century Automatic
The check engine soon light came on this afternoon on my way to work. I'm trying to find out if I can still drive my car around until I am able to take it to a shop to get the code read. Will this damage my vehicle if I drive it until I can get to the mechanic?
Take it to Autozone and get read for free and comeback and give us the code/s. You have an engine management system problem
CMITCHEL
[quote:1ef60e5e9f="rasmataz"]Take it to Autozone and get read for free and comeback and give us the code/s. You have an engine management system problem[/quote:1ef60e5e9f]
Thanks for the info. I have it booked with a local shop as we do not have an Autozone!
JMRAY
1999 buick century ck eng. light came on-auto zone said it showed running lean, egr, and o2 sensor problems. advised me to run inj. cleaner and drive about 50 miles to take care of it. did that-next day it ran like a wagon sometimes-no power on hills and has a slight burn rubber smell when i shut it off. Took to a repair shop-they say it is a misfire on 4 & 5, EGR, and o2 sensor. Could it be all these issues or is it possiblly the cat converter? Can't afford to take it to umpteen shops. also, the CEL started flashing -was told i could drive it but it would be rough. Any ideas where i should really take it? I know its high mileage but can't replace it since i am currently laid off. Thanks for any suggestions.
MMPRINCE4000
  • 8,548 POSTS
The flashing SES light would indicate a convertor problem.
If you can remove convertor (bolted on) look down convertor, if you see signs of overheating, melted material, chunks of material, the convertor is bad.
You must find cause, usually a rich fuel mixture, before replacing convertor.
DATSHORTIEBOO25
Engine Mechanical problem
We have changed the o2 sensors and the egr valve and a couple other things and the light will not go off, this is very frusterating. The codes it is throwing are the p0449 and the p1404 I would like to know where these things are located on my car so I can check them, Thanks
HMAC300
  • 48,601 POSTS
the codes you are talking about could have been set due to teh gas cap not being tightened up. Once the light is set to go offit will have to be closed by the use of a scan tool. IF the problem is fixed it shold go off after about 50 some starts. the one code may be your egr valve is stuck open. You might be able to fix that by taking the egr valve off and cleaning it and then reinstalling it. If not then it will need to be replaced. Sometimes it's better to take it to a pro so you actually save money instead of buying parts and throwing them at it.
GITTY
Engine Cooling problem
1999 Buick Century 157000 miles
My car has been shaking when I drive 50 mph. At times the low coolant light goes off. My mechanic said it's just a bad sensor. The check engine light goes on too. The mechanic says the car may be misfiring. Now the car is overheating. We just had the radiator repaired. What do you suggest is the problem & how much would you anticipate such repairs to cost?
  • 110,190 POSTS
First, has your mechanic even checked anything or assuming the problems? If the check engine light is on, then there is a code stored in the computer that will identify where the problem is coming from. If it is a misfire, it needs to be fixed before it causes other problems.
As far as the overheating, I would start with the thermostat to make sure it isn't sticking shut. Also, let me know if the car overheats at highway speeds or only intown driving.
LEAHRICHARDSON
I JUST HAD MY FUEL PUMP CHANGED AND NOW MY CHECK ENGINE LIGHT IS ON AND THE GAS HAND IS NOT WORKING. i PUT $40 IN MY TANK AND THE HAND IS STILL ON EMPTY
BMRFIXIT
  • 19,053 POSTS
[quote:117618ae51="leahrichardson"]Other Category problem
1999 Buick Century 6 cyl Four Wheel Drive Automatic 100000 miles
I JUST HAD MY FUEL PUMP CHANGED AND NOW MY CHECK ENGINE LIGHT IS ON AND THE GAS HAND IS NOT WORKING. i PUT $40 IN MY TANK AND THE HAND IS STILL ON EMPTY[/quote:117618ae51]
you need to visit the shop that did the job
the sending unit is in tank
JMOSTREGA
1999 Buick Century 6 cyl Automatic
I bought a 99 buick centry yesterday for $99. I took it to auto zoze because the service engine light was on, they told me after doing a diagnostic test that my erg valve was clogged and I needed to clean it out. Where is this located and how do i clean it, Thank you for any advice you can give me
JALOPYPAPA
  • 467 POSTS
It's on the back of the intake manifold, toward the driver's side of center. Here's a diagram of a Chevy; yours should be the same: http://autorepair.about.com/library/images/bl456lib.htm
You'll need to unbolt it from the manifold and the exhaust riser. Equally or more likely to be clogged than the valve itself is its port in the manifold, which sometimes must be removed to clean effectively.
QUANA2010
I have a 1999 buick century and my service engine light came on so i went to get the codes for it. I need to figure out what it is... code po650 and po440
P0650: Malfunction Indicator (MIL) Control Circuit
P0440: Evaporative Emission Control System Malfunction
