2CarPros - Car Questions & Answers
1998 Buick Century Repair Question
Topics covered: Engine, Fuse, Gas.
Asked on October 3, 2010
1998 Buick Century electric cooling fans will not turn on
Engine Cooling problem
1998 Buick Century 6 cyl Two Wheel Drive Automatic
Electric cooling fans will not turn on when engine gets too hot. I checked the fuses and relays. They are good. I replaced the CTS and it did not fix the problem. I did discover that if I disconnect the electrical connector to the CTS, the electric fans will turn on and stay on. I have left the connectors disconnected temporarily so that the engine does not over heat. In doing this, I've noticed a drop in gas mileage. Please help. Oh, the radiator fluid level is good.
Avatar Asked by deanlandis
Answer
Replied on October 3, 2010
the reason your gas mileage dropped is you disconnect the cts and it doesn't control the fans. plug it back in. There are 3 relays not 2 and 2 large fuses. they all must be checked. I'm including a diagram. If it's not a relay, then you'll have to have a pro check it for a bad connection or shorted wire coming from or to the pcm....
http://www.2carpros.com/forum/automotive_pictures/406719_relay_diag_1.jpg
Tiny Answered by hmac300 (expert)
17,932 answers provided
Replied on September 17, 2012
How do you test the relays for the coolant fans
Tiny Answered by douglaseboggs
0 questions asked
