1989 Buick Century
Engine Cooling problem
1989 Buick Century 6 cyl Front Wheel Drive Automatic
i need to know how to remove the thermostat on my car this is a first for me I have allways known how to fix a car
August 24, 2009.
If you follow the upper radiator hose it will lead you to the t-stat housing. Drain the coolant, remove the housing, and it will uncover the t-stat. Make sure you replace the new one in the same direction as the old one.
