Mechanics
BRAKES AND BRAKE BLEEDING
2007 Nissan Altima • 65,000 miles
If I'm going to change the brakes on my 2007 Nissan Altima, do I need to bleed the brakes? If so, do I do it after I replace the brakes and in what order should I bleed it? Do you have instructions on how to bleed the brakes for this car?
Rbmentertainment
May 15, 2013.
No, just pry back the piston slowly. It should go smoothly. Make sure you pump up the pedal when done
roy
ASEMaster6371
May 15, 2013.
