I can feel the brake pedal fade
2006 MITSUBISHI ECLIPSE
GREENJC
  • 7 POSTS
At fifty plus mph when I apply a little bit of pressure to the brake pedal I can feel the brake pedal fade I need a new master can you help me please?
Mar 28, 2009 at 1:33 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Replacing a brake master cylinder takes a little time, but really isn't too hard to do. I recommend getting a lifetime replacement part so you never have to pay for a new one in the future.
First, here is a link that shows in general how it is done. Here are the master cylinder installation instruction you have requested. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://youtu.be/WDxvEQrMkBg
and
https://youtu.be/w7gUsj2us0U
and
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Here are the directions specific to your vehicle. The pics attached below correlate with the directions.
____________________________
With a new master cylinder, it is necessary to bleed it before use. I will start with those directions first.
2006 Mitsubishi Eclipse L4-2.4L (4G69)
Basic Brake System
Vehicle Brakes and Traction Control Hydraulic System Brake Master Cylinder Service and Repair Procedures Master Cylinder Bleeding Basic Brake System
BASIC BRAKE SYSTEM
BLEEDING
CAUTION: Use only brake fluid DOT 3 or DOT 4. Never mix the specified brake fluid with other fluid as it will influence the braking performance significantly.
MASTER CYLINDER BLEEDING
The master cylinder used has no check valve, so if bleeding is carried out by the following procedure, bleeding of air from the brake pipeline will become easier. (When brake fluid is not contained in the master cylinder).
1. Fill the reserve tank with brake fluid.
2. Keep the brake pedal depressed.
pic 1
3. Have another person cover the master cylinder outlet with a finger.
4. With the outlet still closed, release the brake pedal.
5. Repeat steps 2 - 4 three or four times to fill the inside of the master cylinder with brake fluid.
Removal and Replacement
Basic Brake System
Vehicle Brakes and Traction Control Hydraulic System Brake Master Cylinder Service and Repair Procedures Removal and Installation Basic Brake System
BASIC BRAKE SYSTEM
MASTER CYLINDER ASSEMBLY AND BRAKE BOOSTER
REMOVAL AND INSTALLATION
Pre-removal & Post-installation Operation
pic 2
Removal Steps 1-12
pic 3
Removal Steps 1-17 & Required Special Tool
pic 4
INSTALLATION SERVICE POINTS
>>AB
Mar 5, 2021 at 10:51 PM
LEON24540
I'm having a problem with my brakes. I took it to a mechanic earlier this morning and they said that the rotors was warped. So they changed the brakes, rotoras, lines, and replaced the oil. Now my brakes has this air sound to it, and goes all the way to the floor just about before it actually stops. Do you know whats going on with it? They claim i might need a new master cylinder. But why would i? if the brakes was pretty good before i changed every thing? Beside the bad rotors.
Mar 11, 2021 at 1:01 PM (Merged)
KHLOW2008
  • 41,814 POSTS
You need a new master cylider beause it is bad.
Master cylinders can fail after replacing the brakes pads because they would be subjected to further than normal travel during priming up the calipers pistons and this can damage the internal seals.
