Mechanics
BRAKE LIGHTS
1995 Chevrolet Blazer • 169,000 miles
My brake lights are not working, I have replaced the fuses the bulbs seem to be working the parking lights are working, her's where it gets tricky the center light above the tailgate is also working but only like its supposed to be with the brake pedal which leads me to believe that the brake sending switch is good. Can you help?
Ikeslayd
April 30, 2013.
If the same bulb filament is used for the brake light and the turn signal, suspect the signal switch.
Caradiodoc
Apr 30, 2013.
