2001 BMW E46 Repair Question
Topics covered: Four wheel drive, Ignition key, Wheel.
Asked on July 8, 2010
2001 BMW E46 Blower Fan will won't shut off
Electrical problem
2001 BMW E46 6 cyl Four Wheel Drive Automatic 91000 miles
Recently, the blower fan (AC fan) will not shut off even after removing ignition key. The final stage resistor (blower regulator) was replaced a month ago. What part could be bad? I was googling, some said it could be stuck relay, but I can't seem to find where the relay is or it even exists. Please help!
Answer
Replied on July 8, 2010
The part you replaced, was it new from BMW? It may be defective. There isn't a relay. Remove the unit and inspect, if it has a metal case or if you installed a used part, that is where the issue most likely is located. Another method I use is to remove the final stage and if it is hot, it is possibly a defective unit.
