2004 BMW 745
Engine Mechanical problem
2004 BMW 745 V8 Two Wheel Drive Automatic 90,000 miles
It is taking 3-times pusing the Starter button at roughly 5-6 second intervals on the Starter each time, to start my car. Could this be some kind of full pick-up or fuel pump relay switch problem? Where would you start in your investigation?
Also, I get a squeak that comes from the belt or one of the pulleys when the car is good and warm and the RPM's are below 1000, like sitting at a stop light. Would changing the belt help, or would the problem more than likely be coming from one of the pulleys? It doesn't matter if the A/C is on or not, the squeak is the same, so I don't think it's the A/C pump going out.
June 18, 2010.
You are correct about the noise, it is the pulley, its tensioner, or a combination of the two. As to the start issue, when was the last time the car was at the repair facility? The software level may need updating.
Dr. Hagerty
Jun 19, 2010.
