Mechanics
THROTTLE BODY COOLANT LEAK
1988 BMW 325
Engine Cooling problem
1988 BMW 325 6 cyl Two Wheel Drive Manual
It seems that there is a leak in the gasket where in between the throttle feed and throttle return in my cooling system. I do not know the name of the part that is actually leaking, so if anyone can help out that would be great. It's attached to the throttle body, on the left hand side, and it has the throttle feed and return connected to it. It seems that it detaches from the throttle body using star keys. Any help would be appreciated.
AD
Yoshi81
June 18, 2009.
You can bypass the throttle body heater and there will be no ill effects.
Dr. Hagerty
Jul 5, 2009.
AD
