DTC 115 AND 141
1999 BMW 318
Engine Performance problem
1999 BMW 318 4 cyl Two Wheel Drive Manual 107000 miles
Dear Sir
I recently had the clutch and right wishbone changed on my car.
It ran as smooth as a sailing ship.
Then two weeks later they engine began to judder (struggle) when I accelerate. When I dont accelarate the revs fall or are not steady and then fall to cut the engine.
I have had the small breath pipes changed. It solved the problem for two days and then it began again.
A friend used the diagnostic and the above codes showed. Coolant temperature sensor and lambada regulator.
What should I do>?
April 21, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
