Mechanics
BIG MISTAKE INSTALLING "FOUR SEASONS 16152 EVAPORATOR CORE REPAIR KIT WITH WHITE ORIFICE TUBE”
1993 Chevrolet Caprice
HELP!
I tried today to install a product: “Four Seasons 16152 Evaporator Core Repair Kit with White Orifice Tube” since the fitting was leaking. Due to a lack of clear installation instructions (an illustration would have been very helpful), I cut the steel AC line behind the dimpled area assuming that I was supposed to cut the thin line itself rather than the thicker segment into which the orifice tube fits (which is apparently where I was supposed to cut it). Needless to say, the compression fitting was way too large to compress around the smaller diameter tubing. The attached photo shows the segment that I cut out and removed from the car.
What’s done is done. My question is now where do I go from here? Clearly, the repair kit will not work on this line as it is now, as the diameter of the hose is too small. I need to get this thing fixed. How would you advise going about repairing it?
Any help would be GREATLY appreciated!
John
Vintshave
May 23, 2013.
You'll need to replace that line, I thinkit goes form evap to compressor or wherever it goes. Trouble is it may be a dual line like also going to condenser.
Hmac300
May 24, 2013.
It goes directly into the firewall
AD
Vintshave
May 24, 2013.
Any idea where I can find this part? It has to have the wider portion where the orifice tube fits in.
Vintshave
May 24, 2013.
Send me a pic of where it was cut off you still may be able to save this.
Hmac300
May 24, 2013.
AD
