Mechanics
BATTERY WON'T HOLD A CHARGE
2000 Ford Mustang • 125,000 miles
When I start my car, it turns over slowly and takes awhile for it to actually start. I got a jump from a friend a couple of days ago, but the battery seems to drain after the car's been off, even just for an hour. I'd glance at the stereo, and it sometimes resets as though the battery's been disconnected. This morning when I went to start the car, the gauges lit up as they normally do, then a few seconds after I got the car started, the needles dropped to the left as though the car was turned off, then jumped back up to normal again.
Do I just need a new battery, or is the problem more complicated?
Jfritzshall
May 11, 2013.
Have the battery chedkfor condition and load test. Check charging system
Hmac300
May 11, 2013.
AD
