Mechanics
BANGING NOISE WHEN CAR IS PUT IN REVERSE
2002 Honda Civic • 1.7L 4 cylinder 2WD Automatic • 48,000 miles
Hi there is a banging noise when I put the car in reverse. It does this when the car is cold or has been sitting overnight. It also will make the noise when going back to drive as I said only when the car is cold There is no vibration in the car I changed the front mount I think its the rear one but cant see it. Does the exhaust have to be moved to do this mount if its the problem.
Neils2002civic
January 19, 2014.
Check for a broken motor mount or axle play.
Hmac300
Jan 19, 2014.
AD
