Transmission fluid?
GUERRERO8921
  • 2005 CADILLAC DEVILLE
  • V8
  • 80,000 MILES
How do I check the fluid levels for the transmission and what type do I add?
Tuesday, February 8th, 2011 AT 5:18 AM
FACTORYJACK
  • 4,159 POSTS
Engine oil is checked with the indicator with the yellow handle, on the front of the engine. The transmission fill indicator is under the transmission fill cap, near the air cleaner housing. The transmission fluid is checked with the engine running in park. this guide can help
Transmission Fluid Type
Type .................... DEXRON III or Equivalent
AUTOMATIC TRANSMISSION FLUID CAPACITY
Bottom Pan Removal (requires drain plug removal) .................... 7.0 liters (7.4 quarts)
Complete Overhaul (with existing converter) .................... 12.0 liters (12.6 quarts)
Dry .................... 14.2 liters (15.0 quarts)
NOTE: ALL capacity specifications are approximate. When replacing or adding fluids, fill to the recommended level and recheck fluid level.
Tuesday, February 8th, 2011 AT 5:36 AM
CHASEE34
  • V8
  • FWD
  • 157,000 MILES
I put 4 quarts if transmission fluid in now when I check it it shows pretty low di u need to let the car run for awhile before I check it?
Tuesday, January 26th, 2021 AT 6:01 PM (Merged)
JOHNNYT73
  • 924 POSTS
Are you check the level with the car running? What was it showing before you added fluid? Check the fluid level when it is hot. Usually let it idle for a little bit. Run it through all the gears, and check fluid level again.
CHASEE34
U think it will be good to drive 5 hrs away I'm off at college?
JOHNNYT73
  • 924 POSTS
Are you having shifting issues? Seems you could have a leak somewhere.
JANET26
  • 6 POSTS
  • 2004 CADILLAC DEVILLE
  • 98,000 MILES
I need to know how much transmission fluid a 2004 Cadillac deville take is it 6 or 7 quarts can't find it in a book just need to know I change it but not sure how much thank
Tuesday, January 26th, 2021 AT 6:02 PM (Merged)
HMAC300
  • 48,601 POSTS
If you are just changing fluid it will only take about 4 qts due to not replacing all the oil just in pan. It takes 15qts for a completely empty trnasmission
SONNYBOY52
  • 2003 CADILLAC DEVILLE
  • 100,000 MILES
How do I check transmission fluid? Thank you
Tuesday, January 26th, 2021 AT 6:03 PM (Merged)
Here is how you check the fluid level of the transmission with fluid type and capacity.
The dipstick is # 12 in the diagrams below.
4T80-E AUTOMATIC TRANSAXLE
HOW TO CHECK
Be sure to follow all the instructions here, or you could get a false reading on the dipstick.
NOTICE: Too much or too little fluid can damage your transaxle. Too much can mean that some of the fluid could come out and fall on hot engine or exhaust system parts, starting a fire. Too little fluid could cause the transaxle to overheat. Be sure to get an accurate reading if you check your transaxle fluid.
Wait at least 30 minutes before checking the transaxle fluid level if you have been driving:
- When outside temperatures are above 90° F (32° C).
- At high speed for quite a while.
- In heavy traffic - especially in hot weather.
- While pulling a trailer.
- To get the right reading, the fluid should be at normal operating temperature, which is 180° F to 200° F (82° C to 93° C).
- Get the vehicle warmed up by driving about 15 miles (24 km) when outside temperatures are above 50° F (10° C). If it's colder than 50° F (10° C), you may have to drive longer.
CHECKING THE FLUID LEVEL
Prepare you vehicle as follows:
- Park your vehicle on a level place. Keep the engine running.
- With the parking brake applied, place the shift lever in PARK (P).
- With your foot on the brake pedal, move the shift lever through each gear range, pausing for about three seconds in each range. Then, position the shift lever in PARK (P).
- Let the engine run at idle for three to five minutes.
Then, without shutting off the engine, follow these steps:
1. The transaxle fluid cap is located next to the radiator hose and below the engine air cleaner/filter assembly on the driver's side of the vehicle. After removing the engine air cleaner/filter assembly to reach the transaxle fluid cap, turn the cap counterclockwise to remove. Pull out the dipstick and wipe it with a clean rag or paper towel. Push it back in all the way, wait three seconds, and then pull it back out again.
2. Check both sides of the dipstick, and read the lower level. The fluid level must be in the cross-hatched area. If the fluid level is in the acceptable range, push the dipstick back in all the way and turn the handle clockwise. Reinstall the engine air cleaner/filter assembly.
HOW TO ADD FLUID
1. If the fluid level is low, add only enough of the proper fluid to bring the level into the cross-hatched area on the dipstick.
2. Pull out the dipstick. Using a long-neck funnel, add enough fluid at the dipstick hole to bring it to the proper level. It doesn't take much fluid, generally less than one pint (0.5 L). Don't overfill.
NOTICE: We recommend you use only fluid labeled DEXRON -III, because fluid with that label is made especially for your automatic transaxle. Damage caused by fluid other than DEXRON -III is not covered by your new vehicle warranty.
3. After adding fluid, recheck the fluid level as described under How to Check. When the correct fluid level is obtained, push the dipstick back in all the way and turn the handle clockwise.
This guide can help
SONNYBOY52
Thank you. I meant to ask where is the dipstick or add cap to check or add transmission fluid for. I found it thanks to the diagrams.
IZZDOGG
  • 1996 CADILLAC DEVILLE
  • V8
  • 126,000 MILES
My tranny is starting to shift really hard after the engine heats up. Mybuddy who is a mechanic looked at the color of my trnny fluidand said I definately need to change it. Can I do that myself and if so howexactly do I flush the whole tranny. I know i'm going to need a lot of fluid because the tranny is huge. I am mechanically inclined and woulddefinately like to do this work myself. Thanks!
Tuesday, January 26th, 2021 AT 6:04 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
You need special large equipment to do a tranny flush. Would you like the tranny fluid replacement procedures or will you be just taking to a shop to have it flushed?
ZURIE
  • 1994 CADILLAC DEVILLE
  • V8
  • FWD
  • 145,000 MILES
I just restarted my old car after sitting one year. Jumped started the car since the battery was dead. Filled all the fluids, replace air in tires and gas. After driving for 30 minutes. The car started to slow down even when I tried to accelarate. I finall got it home and check the transmission fluid when it was all out. That's when I notice in the front of the car the fluid was squirting out. It looks like the radiator but how is that leaking transmission fluid.
Help. Wondering about the cost of this.
MERLIN2021
  • 17,250 POSTS
The tranny cooler lines screw into the radiator, and there is a tank to cool the fluid, you will need either a new tank, or radiator. Also when the car cools off, open the radiator and check the coolant, we are looking to see if tranny fluid may have also leaked into the coolant! Radiator will run about 200-300 plus labor. Can also be just the line leaking, and that would save a boatload!
ZURIE
Thanks so much. What type of line should I tell them to look at. I'm a girl and I don't want them telling me I need a new transmission when it's just a line. If one goes in and sound like they know what their talking about. I'm less likely to get screwed. LOL Sorry for the language but this is why I try to do my research before going in to the car shop. Thanks for all your help.
MERLIN2021
  • 17,250 POSTS
Look at the transmission cooler lines.
SEAN03
  • 523 POSTS
  • 1992 CADILLAC DEVILLE
  • 135,000 MILES
Yesterday I drained my radiator fluid it was green. I filled it back up with new started the car it sucked it down a little and all of a sudden brown fluid starts rising and gushes out of the radiator and it stinks like oil. I drained it because I did a radiator flush because I installed new water parts. I drained the fluid today it was brown and thick and stunk like hydralic oil. So I checked the oil dip stick twice it was fine oil clean level fine. I pulled the transmission fluid dip stick as soon as I pulled it out it stunk like oil the same smell. It was milky brown. I wiped it off thought it was weird because I checked it last month it was red and clean level perfect. I pulled it out again milky brown stunk smelled burnt and like hydronic fluid. What does this color mean. I am changing the filter and fluid right now and I will change it again in another 3000 miles to make sure I am ok. What do you think. The picture in the bucket of the oil is what I am talking about. Thanks.
CARADIODOC
  • 33,738 POSTS
Sounds like the transmission cooler inside the radiator is leaking. That will let the antifreeze and transmission fluid mix. Replace the radiator, then flush and refill the transmission and cooling system. The transmission fluid in the cooling system will lead to rotted rubber hoses over time if you don't get most of it out. It's more important to get the coolant out of the transmission. A transmission flush and refill might be a good idea.
PIATKOWSKI000
  • 64 POSTS
  • 1984 CADILLAC DEVILLE
Hello. I have 1984 cadillac deville and 87 cadillac brougham. My question is how often should I change automatic transmission fluid? I would like keep those cars in good condition. Thank You.
Tuesday, January 26th, 2021 AT 6:05 PM (Merged)
CARADIODOC
  • 33,738 POSTS
Unless the owner's manual tells you differently, the standard used to be three years or 36,000 miles. A fluid and filter change was the recommended service, and only half of the fluid drains out and is replaced. For maintenance, that is fine. If the cars sit a lot and you put on very few miles, I wouldn't worry about the three years, but you DO want to drive them periodically. As they sit the fluid will run out of the clutch packs and expose the fiber plates to air. When they dry out is when the material flakes off. When rebuilding an automatic it is even standard procedure to soak the new plates in fluid before installing them. Driving the car once every few months will keep the plates covered in fluid so they don't dry out.
If there is debris floating around in the fluid, or the fluid is burned, the damage is already done, but the system can be flushed with special equipment. That replaces all of the fluid but it won't correct the clutch plate material that has already flaked off. Usually a flush is severe overkill.
