2CarPros - Car Questions & Answers
2000 Audi Quattro Repair Question
Topics covered: Axle, Wheel, All wheel drive.
Asked on November 28, 2009
2000 Audi Quattro R.Front Half axle replaced or alignment c
Drive Train Axles Bearings problem
2000 Audi Quattro 4 cyl All Wheel Drive Manual 145000 miles
I had a local mechanic replace my right front half axle with an A1Cardone remanufactured part. (A) are you supposed to do a frojnj end or 4 wheel alignment whenever you change drive train parts? In this case the halfaxle. (B) I ddin't have an alginment done after replacing the half axle, but my car has avibration now that is more noticeable the faster your speed is. Is this likely a problem with the replaced half axle or does it need an alignment? I already had the wheels checked for balancing and they are balanced. THANK YOU.
Avatar Asked by john1633
No Answer Yet
