1990 Audi Quattro
Engine Performance problem
1990 Audi Quattro All Wheel Drive Manual 130000 miles
I have a Audi 1990 200 Quattro turbo 5 cyl. Replaced fuel pump, fuel filter, air filter and it ran great for about 50 miles or more then it started to die after driving it for a while. If I shut off the key when this happens and start it again it runs for a mile or less and shuts off again. If I start it and just let it idle it runs fine even if I rev it up to 4,000 rpm
1990 Audi Quattro Found problem and it runs great now. Had rust in gas tank cleaned it out, took 8 hrs, but fixed problem tried to take quesstion of line but couldn't figure out how to do it
Thanks for being there.
March 28, 2009.
I am concerned now about fuel contamination, did this start after you've filled it up? Did you just break up with your girlfriend? Or your boyfriend?
Dr Loot
May 24, 2009.
