2001 Audi Allroad
Drive Train Axles Bearings problem
2001 Audi Allroad 6 cyl All Wheel Drive Automatic 121000 miles
i am replacing the front right side axle assembly and have already removed outside end axle bolt. I am trying to remove the bolt that the upper control arms pivot on and can not get it to come out. I have removed the nut on the end of it as the manuel says but it is just spinning and not coming out. I have used a numatic chisel on the end of it to try and remove it. And tried to press it out with a c clamp. My question is is there a special tool or procedureto remove this bolt
October 9, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
