2003 Audi A6
2003 AUDI A6
70,000 MILES • 6 CYL • FWD • AUTOMATIC
VISAVIS88
good day. i just bought an 2003 Audi A6 from action with a clean title, but 3 cylinders on the right side of my V6 are not working. The exhaust smoke appears from only one(left) muffler. cam position sensor replacement didn't help. so i'm thinking about buying a new wire set and spark plugs, but before that i want to check is this the ignition problem or not. my question is: how to test the ignition coils, wires and spark plugs on my Audi? if i'll test spark plugs using the way you explained here
http://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
will it be ok, or it will affect car's central computer?
Mar 10, 2009 at 10:49 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
You can test that way without damaging the computer.Also might want to do a compression test on the engine to see if that side is different (skipped timing belt) to be sure you have a properly timed engine before trying to make it run right
Mar 11, 2009 at 7:58 AM
