Mechanics
INTERIOR REAR VIEW MIRROR
1999 Audi A6
Interior problem
1999 Audi A6 6 cyl All Wheel Drive Automatic 156000 miles
I have purchased a used mirror from dad's Audi and I want to replace it myself. The mirror is tinted and has an auto-adjust dimming feature. How do I detach the old mirror and where should I be looking to unplug/plug in the wiring? Thank you.
Snwyrvr
June 21, 2009.
To remove,
Unclip cable channel cover (#3)
Remove connector from retainer and disconnect.
NOTE* do not use cable channel (#2) to turn mirror.
Rotate mirror head (#1) 60 to 90 degrees (look at arrows B) untill retaining spring releases and then removed assembly (look at arrow A)
http://myfiero.com/uploads/17016_.jpg
to install,
Place mirror head (#1) at an angle of 60 to 90 degrees.
Slide assembly in to position (look at arrow A)
Turn mirror head (look at arrows B) until locking springs click in to place.
http://myfiero.com/uploads/17015_.jpg
Buddycraigg
Jun 21, 2009.
AD
