1998 Audi A6 Repair Question
Topics covered: Fuel filter, Tool, Air filter.
Asked on August 15, 2009
1998 Audi A6 FUEL FILTER
Engine Mechanical problem
1998 Audi A6 6 cyl All Wheel Drive Automatic 140000 miles
Where is the location of the fuel filter in an Audi A6 Year 1998
Answer
Replied on August 15, 2009
Fuel filter is located in front right outside at fuel tank
Thank you Steve
So the car has to be on a lift and i guess the filter is easily accessible and can be changed using regular tools - meaning no specialized tools
Thanks again
it would be easier with a lift, but you should be able to do it one the ground. you might need a special torx to get the fuel filter clamp off, but regular hands tools should be ok.
Replied on March 21, 2010
Right next to the top of the air filter box, about the size of an oil filter. Real easy job, simply loosen 2 nuts, replace filter, tighten up nuts.
