2CarPros - Car Questions & Answers
2002 Audi A4 Repair Question
Topics covered: Sensor, Dealer, Engine.
Asked on June 9, 2010
2002 Audi A4 rough idle & engine stall
Engine Performance problem
2002 Audi A4 4 cyl All Wheel Drive Automatic 135555 miles
Initially had a friend diagnose car at his shop & vag com indicated codes for misfires, o2, MAF sensors...suggested change of spark wires, spark plugs, and sensors. Thus far, MAF has been replaced & had the plugs & coils replaced from ignition coil recall at the dealer. The dealer also ran codes that indicated pre cat sensor & engine coolant sensor need replacing. Car still runs at a rough idle & will stall out even after coil & MAF replacement. I've found out that a Vacuum Hose leak may also cause o2 (pre cat) sensor to appear bad. The sensor is $97 ECStuning, $240 @dealer(yeah right!) $170 @audi wholesale & a universal o2 sensor @ Partsbin for $28. My question is how to check if i have a vacuum hose leak $12-$42 for replacement. I don't want to replace parts i don't need to. Which pre cat sensor to purchase? & how to install myself
Avatar Asked by kneelcorpz20
No Answer Yet
