2CarPros - Car Questions & Answers
1991 Audi 90 Repair Question
Topics covered: Sensor, Fuel pressure, Gas.
Asked on November 6, 2009
1991 Audi 90 AUDI 90 2.3L 1991 NOT TICKING,LOW IN POWER,ROU
Engine Mechanical problem
1991 Audi 90 4 cyl Two Wheel Drive Automatic 150000 miles
HELLO BEN AND KEN,
MY AUDI TAPPETS IS NOT NOT TICKING WHEN COLD,I CHANGED LOT OF BIG PRISE PARTS?FOR PAST 7 MONTHS THE CAR BEEN STOP TO 1 MACHANIC AND SECOND,THIRD AND IVE THROWN LOT OF MONEY FOR NOTHING AND THE MACHANIC SAY PROBLEM IS THERE THE MACHANIC NO UNDERSTAND,IM TRAVELING ON BUS TO FROM WORK AND I TAKING MY 3 KIDS TO SCHOOL ON BUS?ITS VERY HARD?IM ON THE LOSE OR LOST SIDE?I VERY VERY MUCH PLEASE AND THANK U ALOT PLEASE *HELP ME?*TILL I SAW UR WEBSITE*AND I READ ALL MOST EVERYTHING WHAT PEOPLE HAVE PROBLEMS,THEY ASK AND U ANSWER THERE PROBLEMS,I THOUGHT I WRITE U ,U CAN HELP ME MY PROBEM?I WANT TO CRY WHILE IM WRITING THIS?THE CAR TAPPETS NOT TICKING WHEN COLD,ROUGH ON FUEL MILAGE,LOW IN POWER 5 CLYD,LACK OF POWER??PLEASE PLEASE HELP ME.*THE MACHANICS NO HAVE COMPUTER TO CHECK CAR COMPUTER,MY CAR IS 19 YEAR OLD SO AUDI DEALER NO HAVE COMPUTER TO CHECK TOO,NO BODY HAVE COMPUTER TO CHECK THIS CAR ON COMPUTER??*PLEASE NOTE THIS CAR NO HAVE EGR VALVE,CAM AND CRANK VALVE?
PLEASE NOTE?I CHANGED THESE NEW PARTS?
STARTER MOTOR=5 INJECTORS=AIR CONTROL VALVE=TROTTLE POISTION VALVE=HEAD GASKET=
MANIFOLD 2 GASKETS=DISTRIBUTER=5 PLUG CABLES=OIL PRESSURE VALVES=WATER TEMPETURE SENSOR=FUEL PUMP=FUEL FILTER=FUEL PRESSURE REGULATOR=THE ALL UNITE OF AIR FLOW METER BECAUSE ITS ALL ONE PART,AIRFLOW SENSOR ,FUEL PRESSURE DISTRIBUTER THEY ALL ONE PARTS?ALL THESE NEW PARTS ARE BOCSH?THANK SO MUCH FOR UR TIME.BASIA
I WROTE TO UR COMPANY THE PROBLEM I HAVE WITH MY AUDI 90 2.3L NG ENGINE 1991.AND I GOT RESPOND FROM 2CARPROS.COM MR RASMATAZAND MR RASMATAZ WROTE ME LIST OF THINGS CAN BE WRONG?NOW I WILL GO TO THE POINT???MR RASMATAZ WROTE ME THE FOLOWING??
Posted at Mon Sep 14, 2009 4:39 pm
By rasmataz, Certified 2CarPros Master Technician
(8132) Give Feedback | Votes: 226
Your problem could be one of the following:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Avatar Asked by basia
No Answer Yet
