1999 Explorer Four wheel drive problems
1999 FORD EXPLORER
MADDISON
  • CAR REPAIR CONTRIBUTOR
  • 28 POSTS
Hi, I have a 1999 ford Explorer XL with 160000 kms. On my four wheel drive switch it shows auto, 4 high and 4 low. I realize that auto means that if the rear wheels spin it will automatically engage the front wheels. My problem is that the truck will stick in 4 wheel drive and not come out until it is ready(sometimes days).Can you give me an area where to start my troubleshooting? The 4 wheel drive works perfectly, except that it will not disengage. Also I was wondering if it is possible to change my transfer case to one that has a two wheel drive setting?
I have tried all of the old tricks. I have owned a couple of the older bronco too and I figured out the old tricks, now I am trying to learn the new ones!
Thanks,
Feb 18, 2006 at 5:42 PM
PEPPERMRJ
  • 1,158 POSTS
With an old fashioned transfer case sometimes you would have to put it in reverse and give it some gas to get it out of 4 wheel drive. Give it a try it cannot hurt anything.
Changing transfer cases would be rather expensive.
Me too. Computerized everything anymore.
My book lists 4 different transfer cases.
Borg Warner 13-54 mechanical shift.
Borg Warner 13-54 electronic shift.
Borg Warner 44-05 control trac
All wheel drive transfer case.
The control trac unit and the electric shift unit operate in the same manner. The system consist of a push button control, an electronic control module, an electric shift motor with an integral shift position sensor and a speed sensor.
The electric shift motor, mounted externally at the rear of the transfer case, drive a rotary helical cam. The cam moves the 2 WD-4 WD shift fork and the 4 HI-4 LOW reduction shift fork to the selected vehicle drive position.
The 44-05 houses a transfer case clutch. The clutch which is controlled by a Generic Control Module (GEM), allows the vehicle to be driven on dry pavement in 4 wheel drive.
I would think that somehow the system would need to detect wheel spin. Maybe it is linked to the anti-lock brake system and it's wheel sensors. Hope this helps.
Good luck with it and let us know how you make out.
Good luck and let us know how you make out. :)
Feb 19, 2006 at 9:55 AM
GODBEAR839
  • 77 POSTS
If you have the all wheel drive transfer case and get on the gas a lot ( I think it is more than 3/4 pedal) the traction control kicks itself in. If you gas it a lot this might be what is holding it in gear in any case check out the motor on the transfer case as they are prone to going bad. When you put it in reverse and gave it some gas this might have told it to stay engaged also.The truck I used to use is to switch into 4 wd/low then back out to verify it was working correctly. If that works then slowly roll forward in neutral and shift back into the normal setting it should come out for you.
Feb 20, 2006 at 10:33 AM
MADDISON
  • 28 POSTS
[quote:9c0236656a="godbear839"]If you have the all wheel drive transfer case and get on the gas alot ( I think it's more than 3/4 pedal) the traction control kicks itself in. If you gas it alot this might be what is holding it in gear in any case check out the motor on the transfer case as they are prone to going bad. and when you put it in reverse and gave it some gas this might have told it to stay engaged also.The truck I used to use is to switch into 4wd/low then back out to verify it was working correctly if that works then slowly roll forward in neutral and shift back into the normal setting it should come out for you.[/quote:9c0236656a] Thanks,I will try that.If it works I am wondering should I replace the shift motor? I have asked around and anyone else who has the auto setting instead of the 2 wd setting says it works great and they do not have any problems. By the way, this site is great! I am a bit of a gear-head myself and I am hoping I will be able to give someone else some advice.Thanks for all the great feedback.
Feb 20, 2006 at 12:13 PM
  • 54,342 POSTS
Hey MADDISON,
yep the transfer case actuator sounds like it is weak and needs replacement, also some of those trucks have a vacuum operated control which goes to the front differential so check the hoses going down to the actuator there as well.
Let me know how it goes,
Ken
May 6, 2016 at 3:43 PM
CHEWNOMORE
I have a 1994 Ford Explorer 4WD. It has the push button on the dash. It goes in and out of 4WD on its own. Can I disconnect the control module in the left rear, to keep the car in two wheel drive permanently? Does that module affect anything else?
Jan 2, 2017 at 11:07 AM (Merged)
PROAUTOTECH
  • 288 POSTS
you could, or you could fix it. The problem is probably a relay between the button and the vacuum line which engages the 4wd. There is probably a vacuum line going to the transfer case that actually engages the 4wd when the button is pressed. If you disconnected that it should stay in 2wd. But I would suggest fixing it before disabling it.
CHEWNOMORE
I have no need for 4wheel drive.I would prefer to make it two wheel drive all the time.Is there any negative to disconnecting the control module. Will it for sure disable the 4 wheel drive and wheel it affect anything else.
PROAUTOTECH
  • 288 POSTS
No, should be just fine. After you disconnect the control module, the transfer case, you can shed a bunch or weight by removing the front driveshaft. Keep all your parts though in case you want to sell it. It's worth more the way it came.
