Alternator Replacement
2005 MITSUBISHI OUTLANDER
170,000 MILES
ANONYMOUS
how to take the alternator off? releasing of the tensioner belt?
Dec 31, 2012 at 11:14 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
> DRIVE BELT REMOVAL
1. Securely insert the spindle handle or ratchet handle with a 12.7 mm (1/2-inch) insertion angle into the jig hole of the auto-tensioner.
2. Rotate the auto-tensioner counterclockwise and align hole A with hole B.
3. Insert an L-shaped hexagon wrench, etc. into the hole to fix and then remove the drive belt.
CAUTION:
To reuse the drive belt, draw an arrow indicating the rotating direction (clockwise) on the back of the belt using chalk, etc.
Dec 31, 2012 at 12:32 PM
  • 54,334 POSTS
Here is a guide that will walk you though the steps with diagrams below to show you on your car.
https://www.2carpros.com/articles/how-to-replace-an-alternator
You should check the alternator once you are done with the job to make sure it is working correctly.
Here is how to do the job on your car (below).
Nov 18, 2017 at 8:59 PM
TONDA SHIPP
Need to know how to remove and install an alternator.
Nov 18, 2017 at 9:00 PM (Merged)
MACMAN5128
how do you get the altanator from the back of the motor so you can change it? i have it loose but ii cant get it out from under the car.
HMAC300
  • 48,601 POSTS
the engine has to be jacked up to get it out you may have to loosen engine mounts.
