Mechanics
94 PASSPORT RUNNING ROUGH
1994 All Other Makes All Other Models
94 passport 3.2L V6. DIS, MPFI. 157k
Engine consumes TWICE the fuel it should.
Engine lacks power, runs rough under heavier acceleration and hills. Occasional black smoke.
OBDI code 44 (o2 sensor reads lean mix)
Lots of upper end chatter
Replaced fuel filter with minimal results.
Air filter is good. Next, I plan to check fuel pump and pressure regulator with a guage, unless that's a bad idea.
1. Is there a way to determine if the fuel injectors are clogged without removing them?
2. What is the probability that this is the problem?
3. Any other suggestions?
Bigbaldtires
May 10, 2007.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
