Mechanics
RIVIERA CAMSHAFT SENSOR REPLACEMENT
1996 All Other Makes All Other Models
I haven't run a test to determine specifically if this is the problem with my 96 Riviera, but a mechanic I work with thinks it is the problem. My car will start fine in the mornings, but once it gets hot, it has trouble starting. If I run arrends, I have to wait for hours to let the engine cool. I'll be honest, I don't know a lot about cars. However, everything I've read suggests that the camshaft position sensor is dead and needs replaced. Is this difficult or is it something an amatuer can do? I appreciate your help. Thanks.
Rowbigred26
December 16, 2006.
If you mean Cranckshaft position sensor,
it may be attached about the flywheel or flex plate
Do a test on it before replacing it, so you won't wast your money.
Mathiaso
Dec 16, 2006.
AD
